I’ve checked a few complaints on the user list claiming the startup time has
become hours long with tens of thousands of layers… at first I thought I could
not reproduce, because I saw the catalog load 10k layers in like 30 seconds,
but later realized the startup sequence was not done and GWC was just killing it.
The trace one sees while that happens is the following:
“main” #1 prio=5 os_prio=0 tid=0x00007fc304018000 nid=0x6f68 runnable [0x00007fc30d70d000]
java.lang.Thread.State: RUNNABLE
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
at java.net.SocketInputStream.read(SocketInputStream.java:170)
at java.net.SocketInputStream.read(SocketInputStream.java:141)
at org.postgresql.core.VisibleBufferedInputStream.readMore(VisibleBufferedInputStream.java:143)
at org.postgresql.core.VisibleBufferedInputStream.ensureBytes(VisibleBufferedInputStream.java:112)
at org.postgresql.core.VisibleBufferedInputStream.read(VisibleBufferedInputStream.java:70)
at org.postgresql.core.PGStream.receiveChar(PGStream.java:283)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1919)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:291)
- locked <0x00000006c7e38fa8> (a org.postgresql.core.v3.QueryExecutorImpl)
at org.postgresql.jdbc.PgStatement.executeInternal(PgStatement.java:432)
at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:358)
at org.postgresql.jdbc.PgStatement.executeWithFlags(PgStatement.java:305)
at org.postgresql.jdbc.PgStatement.executeCachedSql(PgStatement.java:291)
at org.postgresql.jdbc.PgStatement.executeWithFlags(PgStatement.java:269)
at org.postgresql.jdbc.PgStatement.executeQuery(PgStatement.java:236)
at org.postgresql.jdbc.PgDatabaseMetaData.getPrimaryKeys(PgDatabaseMetaData.java:2381)
at org.apache.commons.dbcp.DelegatingDatabaseMetaData.getPrimaryKeys(DelegatingDatabaseMetaData.java:456)
at org.geotools.jdbc.HeuristicPrimaryKeyFinder.getPrimaryKey(HeuristicPrimaryKeyFinder.java:49)
at org.geotools.jdbc.CompositePrimaryKeyFinder.getPrimaryKey(CompositePrimaryKeyFinder.java:52)
at org.geotools.jdbc.JDBCDataStore.getPrimaryKey(JDBCDataStore.java:1095) - locked <0x00000006c66432b8> (a org.geotools.jdbc.JDBCDataStore)
at org.geotools.jdbc.JDBCFeatureSource.(JDBCFeatureSource.java:95)
at org.geotools.jdbc.JDBCDataStore.createFeatureSource(JDBCDataStore.java:941)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:395)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:360)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:344)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:712)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:103)
at org.geoserver.catalog.ResourcePool.getCacheableFeatureType(ResourcePool.java:955) - locked <0x00000006c68de048> (a org.geoserver.catalog.ResourcePool$FeatureTypeCache)
at org.geoserver.catalog.ResourcePool.tryGetFeatureType(ResourcePool.java:936)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:922)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:917)
at org.geoserver.catalog.impl.FeatureTypeInfoImpl.getFeatureType(FeatureTypeInfoImpl.java:120)
at sun.reflect.GeneratedMethodAccessor80.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:147)
at com.sun.proxy.$Proxy10.getFeatureType(Unknown Source)
at org.geoserver.gwc.layer.CatalogConfiguration.isLayerExposable(CatalogConfiguration.java:481)
at org.geoserver.gwc.config.GWCInitializer.addLayersToNotCache(GWCInitializer.java:295)
at org.geoserver.gwc.config.GWCInitializer.initialize(GWCInitializer.java:165)
Basically GWC is checking that each and every cached layer is not referring to a geometryless layer.
That in turn triggers the computation of the table structure for each layer, which of course takes a loooong time
(hours, in the case of the users reporting it).
The method causing the problem has bee introduced in this pull request:
https://github.com/geoserver/geoserver/pull/837
I had no involvement in the development or review of it, but looking at it now, I’m wondering why there
is even a need for it.
First, the code seems to be referring specifically to the GWC in memory caching, which might or might not be enabled,
and second, a geometryless layer is not cachable no matter what. Indeed I’ve tried to configure one:
and going to the tile caching tab I get:
So the check if ta layer is geometryless looks completely superfluous to me.
I would then suggest to remove this check:
I cannot be sure about the other checks (like, I’m not sure why the code would even have to collect on startup
the layers that do not have caching enabled, seems like a check that should be done on demand), but removing this
one at least keeps the startup time under control (10k layers, from startup to a working admin UI in less than a minute)
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
