[Geoserver-devel] h2database dependency
I tried to build geoserver from source for the first time a couple of weeks ago. The only problem I hit was with the org.h2database dependency in the root pom and the WMS project pom. As near as I can tell, all h2 artifacts are now posted under com.h2database rather than org.h2database. I could find version 1.1.110 under the former, but not the latter. Am I missing something obvious, or do these references need to be updated? I’ve only been working with maven for a few months, so my apologies if I’m missing something obvious. I think I must be since other people can obviously compile.
e
Eric Sword wrote:
I tried to build geoserver from source for the first time a couple of weeks ago. The only problem I hit was with the org.h2database dependency in the root pom and the WMS project pom. As near as I can tell, all h2 artifacts are now posted under com.h2database rather than org.h2database. I could find version 1.1.110 under the former, but not the latter. Am I missing something obvious, or do these references need to be updated? I've only been working with maven for a few months, so my apologies if I'm missing something obvious. I think I must be since other people can obviously compile.
e
The usual problem with Maven is that if you build multiple projects your local repository contains the union of all the depencies. So if GeoTools includes all the right repositories, and GeoServer is missing some, then no GeoServer developer is going to notice because they build GT all the time anyway.
But I've been publishing those jars to http://repo.opengeo.org/org/h2database/h2/ , and that's a repo in trunk/src/pom.xml . What version of GeoServer are you trying to build ?
-Arne
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
(Please CC list)
1.7.x/src/pom.xml also has a reference to repo.opengeo.org.
Can you provide the maven traceback , including the part where it tries and fails repos for this particular jar ?
-Arne
Eric Sword wrote:
Latest from 1.7.x branch.
On Thu, Sep 24, 2009 at 3:08 AM, Arne Kepp <ak@anonymised.com <mailto:ak@anonymised.com>> wrote:
        e
    build ?
    -Arne
    -- Arne Kepp
Arne Kepp
Very odd. I just noticed that I do have org.h2database:h2:1.1.116 in my local repository and it was pulled down only about 30 minutes after the com.h2database 1.1.110 version back when I did the compile on 9/6 (around 2:30 EST). So maybe there was just a temporary blip in my communications. I’m mirroring everything through a nexus server at work and I possibly didn’t have the opengeo mirror in there correctly when I first tried. Sorry for the false alarm.
One last question though - why are you posting it under org.h2database rather than com.h2database? Habit?
Thanks for the help,
e
On Thu, Sep 24, 2009 at 4:15 AM, Arne Kepp <ak@anonymised.com> wrote:
(Please CC list)
-Arne
On Thu, Sep 24, 2009 at 3:08 AM, Arne Kepp <ak@anonymised.com mailto:[ak@anonymised.com](mailto:ak@anonymised.com.1501...)> wrote:
e
But I’ve been publishing those jars to
http://repo.opengeo.org/org/h2database/h2/ , and that’s a repo in
build ?
-Arne
– Arne Kepp
Arne Kepp
Habit by now, and all the classes care called org.h2, so either one is inconsistent..
-Arne
Eric Sword wrote:
Very odd. I just noticed that I do have org.h2database:h2:1.1.116 in my local repository and it was pulled down only about 30 minutes after the com.h2database 1.1.110 version back when I did the compile on 9/6 (around 2:30 EST). So maybe there was just a temporary blip in my communications. I'm mirroring everything through a nexus server at work and I possibly didn't have the opengeo mirror in there correctly when I first tried. Sorry for the false alarm.
e
On Thu, Sep 24, 2009 at 4:15 AM, Arne Kepp <ak@anonymised.com <mailto:ak@anonymised.com>> wrote:
    (Please CC list)
    <http://repo.opengeo.org>.
    -Arne
        <mailto:ak@anonymised.com> <mailto:ak@anonymised.com
        project
        posted
        could find
        to be
        months,
        think I
               e
        repositories, and
        going to
        repo in
           build ?
           -Arne
           -- Arne Kepp
    -- Arne Kepp
Arne Kepp
