[Geoserver-devel] Hate mails from build serve re-instated
the build server was not yet sending mails about build failures due to mis-configured smtp
password. I’ve corrected it, we might have to fine tune the config on a per job basis, in case
they start sending unwanted mails (e.g., jobs that are still not stabilized on the new build server)
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thanks Andrea,
I noticed that the new server messages were being addressed as “address not configured yet” - I’ve fixed that, future mail should say its coming from “Jenkins”.
Torben
On Tue, May 26, 2020 at 1:21 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-devel mailing list
