This message appears in the screen when i execute
$[GEOSERVER_HOME]/bin/startup.jar
What is going on?!
Please help
thanks!
Message:
18:06:02.728 EVENT Checking Resource aliases
18:06:03.749 EVENT Starting Jetty/4.2.21
18:06:03.769 EVENT Started ServletHttpContext[/]
18:06:03.774 EVENT Started SocketListener on 0:0:0:0:0:0:0:1:8081
18:06:03.775 EVENT Started org.mortbay.jetty.Server@anonymised.com
18:06:03.833 EVENT Starting Jetty/4.2.21
18:06:04.005 EVENT Started WebApplicationContext[/geoserver,GeoServer]
log4j:WARN No appenders could be found for logger
(org.apache.struts.util.PropertyMessageResources).
log4j:WARN Please initialize the log4j system properly.
174 [FINE] org.geotools.styling.MarkImpl - creating defaultMark
292 [FINE] org.geotools.styling.MarkImpl - creating defaultMark
294 [FINE] org.geotools.styling.MarkImpl - creating defaultMark
18:06:07.970 WARN!! action: null
java.lang.ClassCastException
at org.geotools.factory.FactoryFinder$1.next(FactoryFinder.java:471)
at
org.geotools.data.DataStoreFinder.getAvailableDataStores(DataStoreFinder.java:110)
at
org.vfny.geoserver.action.data.DataStoreUtils.aquireFactory(DataStoreUtils.java:81)
at
org.vfny.geoserver.config.DataStoreConfig.reset(DataStoreConfig.java:107)
at
org.vfny.geoserver.config.DataStoreConfig.<init>(DataStoreConfig.java:92)
at org.vfny.geoserver.config.DataConfig.update(DataConfig.java:191)
at org.vfny.geoserver.config.DataConfig.<init>(DataConfig.java:163)
at org.vfny.geoserver.config.ConfigPlugIn.init(ConfigPlugIn.java:95)
at
org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServlet.java:1158)
at org.apache.struts.action.ActionServlet.init(ActionServlet.java:473)
at javax.servlet.GenericServlet.init(GenericServlet.java:256)
at org.mortbay.jetty.servlet.ServletHolder.start(ServletHolder.java:220)
at
org.mortbay.jetty.servlet.ServletHandler.initializeServlets(ServletHandler.java:445)
at
org.mortbay.jetty.servlet.WebApplicationHandler.initializeServlets(WebApplicationHandler.java:150)
at
org.mortbay.jetty.servlet.WebApplicationContext.start(WebApplicationContext.java:458)
at org.mortbay.http.HttpServer.start(HttpServer.java:663)
at org.mortbay.jetty.Server.main(Server.java:429)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.mortbay.start.Main.invokeMain(Main.java:152)
at org.mortbay.start.Main.start(Main.java:482)
at org.mortbay.start.Main.main(Main.java:90)
18:06:07.981 EVENT action: null: java.lang.ClassCastException
18:06:07.985 EVENT Started SocketListener on 0.0.0.0:8080
18:06:07.986 WARN!!
org.mortbay.util.MultiException[javax.servlet.UnavailableException]
at org.mortbay.http.HttpServer.start(HttpServer.java:640)
at
at
[0]=javax.servlet.UnavailableException
at
org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServlet.java:1169)
at
at
at
at
at
This message was sent using IMP, the Internet Messaging Program.
