[Geoserver-devel] HELP : problem compiling geoserver : version 2.6.0
Hello,
I can not compile (mvn compile) the code of geoserver 2.6.0 (Web Coverage Service 1.1 Module 2.6.0). I use MAVEN 3.2.1 and JDK 1.7.0_71 .
Thank you in advance for your help
Best regards
Here are the errors :
[INFO] Building Web Coverage Service 1.1 Module 2.6.0
[INFO]
[INFO] — git-commit-id-plugin:2.0.4:revision (default) @ gs-wcs1_1 —
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO]
[INFO] — javacc-maven-plugin:2.3:jjtree (jjtree) @ gs-wcs1_1 —
[INFO] Nothing to process - all grammars in C:\Data\users\didier\eclipse\workspa
ces\geoserver\geoserver-2.6.0\src\wcs1_1\src\main\java\org\geoserver\wcs\kvp\ran
gesubset are up to date.
[INFO]
[INFO] — javacc-maven-plugin:2.3:javacc (javacc) @ gs-wcs1_1 —
Java Compiler Compiler Version 4.0 (Parser Generator)
(type “javacc” with no arguments for help)
Reading from file C:\Data\users\didier\eclipse\workspaces\geoserver\geoserver-2.
6.0\src\wcs1_1\target\jjtree\org\geoserver\wcs\kvp\rangesubset\rangeset.jj . . .
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer … SUCCESS [ 0.312 s]
[INFO] Core Platform Module … SUCCESS [ 0.674 s]
[INFO] Open Web Service Module … SUCCESS [ 0.390 s]
[INFO] Main Module … SUCCESS [ 2.846 s]
[INFO] GeoServer Security Modules … SUCCESS [ 0.040 s]
[INFO] GeoServer JDBC Security Module … SUCCESS [ 0.210 s]
[INFO] GeoServer LDAP Security Module … SUCCESS [ 0.280 s]
[INFO] Web Coverage Service Module … SUCCESS [ 0.180 s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [ 0.217 s]
[INFO] Web Coverage Service 1.1 Module … SKIPPED
[INFO] Web Coverage Service 2.0 Module … SKIPPED
[INFO] Web Feature Service Module … SKIPPED
[INFO] Web Map Service Module … SKIPPED
[INFO] KML support for GeoServer … SKIPPED
[INFO] GeoWebCache (GWC) Module … SKIPPED
[INFO] REST Support Module … SKIPPED
[INFO] REST Configuration Service Module … SKIPPED
[INFO] GeoServer Web Modules … SKIPPED
[INFO] Core UI Module … SKIPPED
[INFO] WMS UI Module … SKIPPED
[INFO] GWC UI Module … SKIPPED
[INFO] WFS UI Module … SKIPPED
[INFO] Demoes Module … SKIPPED
[INFO] WCS UI Module … SKIPPED
[INFO] Security UI Modules … SKIPPED
[INFO] Security UI Core Module … SKIPPED
[INFO] Security UI JDBC Module … SKIPPED
[INFO] Security UI LDAP Module … SKIPPED
[INFO] REST UI Module … SKIPPED
[INFO] GeoServer Web Application … SKIPPED
[INFO] Community Space … SKIPPED
[INFO] GeoServer Extensions … SKIPPED
[INFO] BUILD SUCCESS
[INFO] Total time: 6.756 s
[INFO] Finished at: 2014-11-05T14:24:20+01:00
[INFO] Final Memory: 24M/247M
constituent[0]: file:/C:/apache-maven-3.2.1/lib/aether-api-0.9.0.M2.jar
constituent[1]: file:/C:/apache-maven-3.2.1/lib/aether-connector-wagon-0.9.0.M2.
jar
constituent[2]: file:/C:/apache-maven-3.2.1/lib/aether-impl-0.9.0.M2.jar
constituent[3]: file:/C:/apache-maven-3.2.1/lib/aether-spi-0.9.0.M2.jar
constituent[4]: file:/C:/apache-maven-3.2.1/lib/aether-util-0.9.0.M2.jar
constituent[5]: file:/C:/apache-maven-3.2.1/lib/aopalliance-1.0.jar
constituent[6]: file:/C:/apache-maven-3.2.1/lib/cdi-api-1.0.jar
constituent[7]: file:/C:/apache-maven-3.2.1/lib/commons-cli-1.2.jar
constituent[8]: file:/C:/apache-maven-3.2.1/lib/commons-io-2.2.jar
constituent[9]: file:/C:/apache-maven-3.2.1/lib/commons-lang-2.6.jar
constituent[10]: file:/C:/apache-maven-3.2.1/lib/guava-14.0.1.jar
constituent[11]: file:/C:/apache-maven-3.2.1/lib/javax.inject-1.jar
constituent[12]: file:/C:/apache-maven-3.2.1/lib/jsoup-1.7.2.jar
constituent[13]: file:/C:/apache-maven-3.2.1/lib/jsr250-api-1.0.jar
constituent[14]: file:/C:/apache-maven-3.2.1/lib/maven-aether-provider-3.2.1.jar
constituent[15]: file:/C:/apache-maven-3.2.1/lib/maven-artifact-3.2.1.jar
constituent[16]: file:/C:/apache-maven-3.2.1/lib/maven-compat-3.2.1.jar
constituent[17]: file:/C:/apache-maven-3.2.1/lib/maven-core-3.2.1.jar
constituent[18]: file:/C:/apache-maven-3.2.1/lib/maven-embedder-3.2.1.jar
constituent[19]: file:/C:/apache-maven-3.2.1/lib/maven-model-3.2.1.jar
constituent[20]: file:/C:/apache-maven-3.2.1/lib/maven-model-builder-3.2.1.jar
constituent[21]: file:/C:/apache-maven-3.2.1/lib/maven-plugin-api-3.2.1.jar
constituent[22]: file:/C:/apache-maven-3.2.1/lib/maven-repository-metadata-3.2.1
.jar
constituent[23]: file:/C:/apache-maven-3.2.1/lib/maven-settings-3.2.1.jar
constituent[24]: file:/C:/apache-maven-3.2.1/lib/maven-settings-builder-3.2.1.ja
r
constituent[25]: file:/C:/apache-maven-3.2.1/lib/org.eclipse.sisu.inject-0.0.0.M
5.jar
constituent[26]: file:/C:/apache-maven-3.2.1/lib/org.eclipse.sisu.plexus-0.0.0.M
5.jar
constituent[27]: file:/C:/apache-maven-3.2.1/lib/plexus-cipher-1.7.jar
constituent[28]: file:/C:/apache-maven-3.2.1/lib/plexus-component-annotations-1.
5.5.jar
constituent[29]: file:/C:/apache-maven-3.2.1/lib/plexus-interpolation-1.19.jar
constituent[30]: file:/C:/apache-maven-3.2.1/lib/plexus-sec-dispatcher-1.3.jar
constituent[31]: file:/C:/apache-maven-3.2.1/lib/plexus-utils-3.0.17.jar
constituent[32]: file:/C:/apache-maven-3.2.1/lib/sisu-guice-3.1.3-no_aop.jar
constituent[33]: file:/C:/apache-maven-3.2.1/lib/slf4j-api-1.7.5.jar
constituent[34]: file:/C:/apache-maven-3.2.1/lib/slf4j-simple-1.7.5.jar
constituent[35]: file:/C:/apache-maven-3.2.1/lib/wagon-file-2.6.jar
constituent[36]: file:/C:/apache-maven-3.2.1/lib/wagon-http-2.6-shaded.jar
constituent[37]: file:/C:/apache-maven-3.2.1/lib/wagon-http-shared-2.6.jar
constituent[38]: file:/C:/apache-maven-3.2.1/lib/wagon-provider-api-2.6.jar
constituent[39]: file:/C:/apache-maven-3.2.1/conf/logging/
Exception in thread “main” java.lang.Error: Invalid escape character at line 1 c
olumn 69.
at org.javacc.parser.JavaCharStream.readChar(Unknown Source)
at org.javacc.parser.JavaCCParserTokenManager.getNextToken(Unknown Sourc
e)
at org.javacc.parser.JavaCCParser.jj_ntk(Unknown Source)
at org.javacc.parser.JavaCCParser.javacc_options(Unknown Source)
at org.javacc.parser.JavaCCParser.javacc_input(Unknown Source)
at org.javacc.parser.Main.mainProgram(Unknown Source)
at org.codehaus.mojo.javacc.JavaCCMojo.execute(JavaCCMojo.java:369)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(Default
BuildPluginManager.java:133)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor
.java:208)
.java:153)
.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProje
ct(LifecycleModuleBuilder.java:108)
ct(LifecycleModuleBuilder.java:76)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThre
adedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(Lifecycl
eStarter.java:116)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:361)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:155)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:584)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:213)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:157)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Laun
cher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.jav
a:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(La
uncher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:
356)
Hi Didier,
my guess is that you have issues with the source checkout… All files should be in UTF-8, maybe your system has troubles with them?
How did you get the sources?
On Wed, Nov 5, 2014 at 2:32 PM, LACAMBRE Didier <didier.lacambre@anonymised.com> wrote:
Hello,
Best regards
[INFO]
[INFO]
[INFO]
[INFO]
jar
.jar
r
5.jar
5.jar
5.5.jar
olumn 69.
e)
.java:208)
.java:153)
.java:145)
eStarter.java:116)
java:57)
sorImpl.java:43)
cher.java:289)
a:229)
uncher.java:415)
356)
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
