[Geoserver-devel] How to apply CQL Filter on FeatureType Property that contains Json Object
I have mssql datastore and named layer Compressor generated based on SQL view
query that I want to filter from Openlayer wms request based on Property
EntityUser that contains JSON object with a key.
Sample JSON that contains EntityUser Column/Property is:
                "4742ed9e-384c-41fe-9240-8ced1da67759": {
                        "242b5425-2abb-45f1-8f6f-e962ef0861e0":
["746c8188-0125-41f5-aa61-e42c753a77ac"]
                "fff4f98e-cddd-4c7e-aa3e-57e20ec682e9": {
So how I apply cql or ogc filter on Property that having JSONObject?
Layer Preview Image:
<http://osgeo-org.1560.x6.nabble.com/file/t381824/cql_filter_on_EntityUser_Property.png&gt;
And also suggest what are all the way possible to filter layer.
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-Dev-f3819232.html
As far as I know filtering with CQL\OGC Filter\ECQL on the JSON content of a property is not possible, for GeoServer the EntityUser value is just a normal String.
I can see two paths for this:
  • Implement a custom function that would help you dealing with JSON and then use it in the CQL filter
  • for example a function that given a certain path extract the correspond value from JSON
  • create a view, a real view in the database or a GeoServer view, that would put the content of the
Hope it helps,
Nuno Oliveira
[<http://osgeo-org.1560.x6.nabble.com/file/t381824/cql_filter_on_EntityUser_Property.png>](http://osgeo-org.1560.x6.nabble.com/file/t381824/cql_filter_on_EntityUser_Property.png)
Sent from: [http://osgeo-org.1560.x6.nabble.com/GeoServer-Dev-f3819232.html](http://osgeo-org.1560.x6.nabble.com/GeoServer-Dev-f3819232.html)
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
55054  Massarosa (LU)
fax:      +39 0584 1660272
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
We did something like Nuno's first suggestion in GeoMesa:
https://github.com/locationtech/geomesa/blob/master/geomesa-features/geomesa-feature-kryo/src/main/scala/org/locationtech/geomesa/features/kryo/json/JsonPathFilterFunction.scala
https://github.com/locationtech/geomesa/blob/master/geomesa-features/geomesa-feature-kryo/src/test/scala/org/locationtech/geomesa/features/kryo/json/JsonPathFilterFunctionTest.scala
In the short term, one may be able to drop in the geomesa-feature-kryo jar (with enough dependencies) to make things work.
Jim
On 03/20/2018 04:57 PM, Nuno Oliveira wrote:
  * Implement a custom function that would help you dealing with JSON
      o for example a function that given a certain path extract the
  * create a view, a real view in the database or a GeoServer view,
Hope it helps,
Nuno Oliveira
Sent from:http://osgeo-org.1560.x6.nabble.com/GeoServer-Dev-f3819232.html
engaging tech sites, Slashdot.org!http://sdm.link/slashdot
Nuno Oliveira
GeoServer Professional Services from the experts! Visithttp://goo.gl/it488V for more information.
@nmcoliveira
Software Engineer
To work... slowly (against anything by small datasets) as the function is
evaluated in memory.
For good performance, one should also implement translation of the function
down into native SQL
(an exercise left for the reader :wink: )
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Right, e.g. PostgreSQL has some support for JSON.
On 03/21/2018 05:06 PM, Andrea Aime wrote:
To work… slowly (against anything by small datasets) as the function is evaluated in memory.
For good performance, one should also implement translation of the function down into native SQL
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
Nuno Oliveira
@nmcoliveira
Software Engineer
