[Geoserver-devel] How to delete datastore from Geoserver
Hi, everyone, I create a new datastore based on shp.I try to delete it. I use config/data/stores/ and select the datastore and click "delete" button. It does delete the datastore from the list. But when Geoserver restart, the datastore is still there. How to delete it completely?
Cathy
_________________________________________________________________
ÏíÓÃÊÀ½çÉÏ×î´óµÄµç×ÓÓʼþϵͳ¡ª MSN Hotmail¡£ http://www.hotmail.com
Hi Cathy,
On the left hand side of the ui you should see two buttons, Apply and
Save. After you delete press Apply, then Save. This should persist the
configuration to disk.
-Justin
Cathy
享用世界上最大的电子邮件系统— MSN Hotmail。 http://www.hotmail.com
This SF.net email is sponsored by: Splunk Inc. Do you grep through log
files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=103432&bid=230486&dat=121642
Geoserver-devel mailing list
Justin Deoliveira
jdeolive@anonymised.com
The Open Planning Project
http://topp.openplans.org
Hi
After you delete the datastore, you have to hit the 'Apply' button for
the change to take effect. Then you have to hit the 'Save' button to
persist the change so it is the same when you restart GeoServer. The
Apply and Save buttons are on the left hand side of the screen in the
config section.
Brent Owens
(The Open Planning Project)
completely?
Cathy
files
