it seems the build server is borderline unresponsive… requests do not time out, but even reaching
the UI takes about a minute for me, and every subsequent request is also very slow.
The builders seem to be inactive.
Any clue?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I saw a bit of slowness on and off yesterday, however it seems to be running fine for me now. Are you still having issues?
Given that the problem seems to have cleared itself up, I would guess its just AWS acting up, but if the problem persists I can look into it further.
Torben
On Wed, May 8, 2019 at 5:52 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Any clue?
Geoserver-devel mailing list
I’m now seeing slowdowns again. Looking into it.
Torben
On Wed, May 8, 2019 at 9:27 AM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Any clue?
