Aaah yep, it’s a big one for sure… PMD upgrade to version 7. They rewrote the java scanner
and it’s not much better at finding violations.
441 files modified in the PR so far, quite a bit of modules not yet reached by the build, and this is the
current output:
Error: 0,053 [ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.22.0:check (default) on project gs-web-core: You have 43 PMD violations. For more details see: /home/runner/work/geoserver/geoserver/src/web/core/target/pmd.xml → [Help 1]
Error: 0,053 [ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.22.0:check (default) on project gs-restconfig: You have 4 PMD violations. For more details see: /home/runner/work/geoserver/geoserver/src/restconfig/target/pmd.xml → [Help 1]
Error: 0,053 [ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.22.0:check (default) on project gs-sample-data-access-test: You have 2 PMD violations. For more details see: /home/runner/work/geoserver/geoserver/src/extension/app-schema/sample-data-access-test/target/pmd.xml → [Help 1]
Error: 0,053 [ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.22.0:check (default) on project gs-excel: You have 1 PMD violation. For more details see: /home/runner/work/geoserver/geoserver/src/extension/excel/target/pmd.xml → [Help 1]
Error: 0,053 [ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.22.0:check (default) on project gs-dxf-core: You have 1 PMD violation. For more details see: /home/runner/work/geoserver/geoserver/src/extension/dxf/core/target/pmd.xml → [Help 1]
Error: 0,054 [ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.22.0:check (default) on project gs-sec-jdbc: You have 4 PMD violations. For more details see: /home/runner/work/geoserver/geoserver/src/security/jdbc/target/pmd.xml → [Help 1]
Error: 0,054 [ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.22.0:check (default) on project gs-csw-simple-store: You have 1 PMD violation. For more details see: /home/runner/work/geoserver/geoserver/src/extension/csw/simple-store/target/pmd.xml → [Help 1]
Error: 0,054 [ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.22.0:check (default) on project gs-wms: You have 95 PMD violations. For more details see: /home/runner/work/geoserver/geoserver/src/wms/target/pmd.xml → [Help 1]
Error: 0,054 [ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.22.0:check (default) on project gs-wcs2_0-eo-core: You have 2 PMD violations. For more details see: /home/runner/work/geoserver/geoserver/src/extension/wcs2_0-eo/core/target/pmd.xml → [Help 1]
Error: 0,054 [ERROR] Failed to execute goal org.apache.maven.plugins:maven-pmd-plugin:3.22.0:check (default) on project gs-wps-core: You have 24 PMD violations. For more details see: /home/runner/work/geoserver/geoserver/src/extension/wps/wps-core/target/pmd.xml → [Help 1]
200+ violations just here LOL. Yes, it needs to be a group effort, no doubt.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
