[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.1.x-deploy #646
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/646/&gt;
[...truncated 10496 lines...]
182/178K
186/178K
190/178K
194/178K
198/178K
202/178K
206/178K
210/178K
214/178K
218/178K
222/178K
226/178K
230/178K
234/178K
238/178K
242/178K
246/178K
250/178K
254/178K
258/178K
262/178K
266/178K
270/178K
274/178K
278/178K
282/178K
286/178K
290/178K
294/178K
298/178K
302/178K
306/178K
310/178K
314/178K
318/178K
322/178K
326/178K
330/178K
334/178K
338/178K
342/178K
346/178K
350/178K
354/178K
357/178K
178K uploaded (monitoring-2.1-SNAPSHOT.jar)
[INFO] Retrieving previous metadata from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '3b2cf74bb32834a727b76b5494969f8a8fa96d5a'; remote = '5b93ede93cab5b429f139942fcc58e04ebaff8fc' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '3b2cf74bb32834a727b76b5494969f8a8fa96d5a'; remote = '5b93ede93cab5b429f139942fcc58e04ebaff8fc' - IGNORING
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.community:monitoring:2.1-SNAPSHOT'
[INFO] Uploading project information for monitoring 2.1-SNAPSHOT
[INFO] Uploading repository metadata for: 'artifact org.geoserver.community:monitoring'
[INFO] Retrieving previous build number from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '843fb9d929c94d907d880b10e57e54b300c2ffc4'; remote = '502d3bbfba3568613a3999e52e1f2c1c03eb5b19' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '843fb9d929c94d907d880b10e57e54b300c2ffc4'; remote = '502d3bbfba3568613a3999e52e1f2c1c03eb5b19' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/community/monitoring/2.1-SNAPSHOT/monitoring-2.1-SNAPSHOT-tests.jar
4/59K
8/59K
12/59K
16/59K
20/59K
24/59K
28/59K
32/59K
36/59K
40/59K
44/59K
48/59K
52/59K
56/59K
59/59K
63/59K
67/59K
71/59K
75/59K
79/59K
83/59K
87/59K
91/59K
95/59K
99/59K
103/59K
107/59K
111/59K
115/59K
119/59K
59K uploaded (monitoring-2.1-SNAPSHOT-tests.jar)
Uploading: http://repo.opengeo.org/org/geoserver/community/monitoring/2.1-SNAPSHOT/monitoring-2.1-SNAPSHOT-sources.jar
4/94K
8/94K
12/94K
16/94K
20/94K
24/94K
28/94K
32/94K
36/94K
40/94K
44/94K
48/94K
52/94K
56/94K
60/94K
64/94K
68/94K
72/94K
76/94K
80/94K
84/94K
88/94K
92/94K
94/94K
98/94K
102/94K
106/94K
110/94K
114/94K
118/94K
122/94K
126/94K
130/94K
134/94K
138/94K
142/94K
146/94K
150/94K
154/94K
158/94K
162/94K
166/94K
170/94K
174/94K
178/94K
182/94K
186/94K
189/94K
94K uploaded (monitoring-2.1-SNAPSHOT-sources.jar)
Uploading: http://repo.opengeo.org/org/geoserver/community/monitoring/2.1-SNAPSHOT/monitoring-2.1-SNAPSHOT-test-sources.jar
4/37K
8/37K
12/37K
16/37K
20/37K
24/37K
28/37K
32/37K
36/37K
37/37K
41/37K
45/37K
49/37K
53/37K
57/37K
61/37K
65/37K
69/37K
73/37K
75/37K
37K uploaded (monitoring-2.1-SNAPSHOT-test-sources.jar)
[INFO] Building GeoServer Web Application
[INFO] task-segment: [deploy]
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/web/app&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/web/app/src/main/resources&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/web/app/src/main/java&gt;
Downloading: http://repo.opengeo.org//org/geotools/ogc/org.w3.xlink/2.7-SNAPSHOT/org.w3.xlink-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml2/2.7-SNAPSHOT/gt-xsd-gml2-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile/2.7-SNAPSHOT/gt-shapefile-2.7-SNAPSHOT.jar
[INFO] No sources to compile
[INFO] Copying 1 resource
[INFO] Nothing to compile - all classes are up to date
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/web/app/target/web-app-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/web/app/target/web-app-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] snapshot org.geoserver.maven:config:2.1-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/web/app/target/web-app-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/web/app/target/web-app-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] [config:config {execution: configPackage}]
config:
[ERROR] BUILD ERROR
[INFO] Failed to execute: Executing Ant script: /config.build.xml [config]: Failed to execute.
Unable to locate configuration: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/web/app/minimal&gt;
[INFO] Total time: 1 minute 11 seconds
[INFO] Finished at: Tue Jul 03 14:21:15 UTC 2012
[INFO] Final Memory: 70M/252M
