See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/242/>
[...truncated 27948 lines...]
</ows:ExceptionReport>
17 Feb 19:57:14 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: No service: ( ows )
at org.geoserver.ows.Dispatcher.service(Dispatcher.java:518)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:250)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:606)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:589)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:574)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:859)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:823)
at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestMandatoryRequestParameter(CapabilitiesSystemTest.java:232)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor253.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
org.geoserver.platform.ServiceException: WMS capabilities document is current (updateSequence = 3)
at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:62)
at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:326)
at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:70)
at sun.reflect.GeneratedMethodAccessor169.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy14.getCapabilities(Unknown Source)
at sun.reflect.GeneratedMethodAccessor168.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:772)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:267)
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc src/test/resources/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd"> <ServiceException code="CurrentUpdateSequence">
</ServiceException>
</ServiceExceptionReport>
17 Feb 19:57:15 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Client supplied an updateSequence that is greater than the current server updateSequence
at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:57)
at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:284)
Tests run: 6, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 35.542 sec <<< FAILURE!
Running org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest
17 Feb 19:57:15 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock4800317977298724121data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock4679183596228480910data>
17 Feb 19:57:16 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock126424496494747464data>
17 Feb 19:57:17 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock3097849827409954041data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock3705976246436646751data>
17 Feb 19:57:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock5762273896715441468data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock6728495549862599317data>
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.502 sec
Results :
Tests in error:
testValidateCapabilitiesXML(org.geoserver.wms.wms_1_3.CapabilitiesSystemTest)
Tests run: 510, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/target/surefire-reports> for the individual test results.
[INFO] Total time: 11 minutes 48 seconds
[INFO] Finished at: Sun Feb 17 19:57:19 UTC 2013
[INFO] Final Memory: 57M/388M
