[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.3.x #139
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/139/changes&gt;
Changes:
[Andrea Aime] [GEOS-5800] GeoServer won't parse relative external graphic locations in SE 1.1 styles
Started by an SCM change
Checkout:workspace / <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/&gt; - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision 21ad3c933adfc2c6d67841e23d86f2c0af583f04 (origin/2.3.x)
Fetching changes from the remote Git repository
Fetching upstream changes from git://github.com/geoserver/geoserver.git
Commencing build of Revision 8114587c9502fbd7ad5653ea5a4cf8aeb0015e37 (origin/2.3.x)
Checking out Revision 8114587c9502fbd7ad5653ea5a4cf8aeb0015e37 (origin/2.3.x)
[workspace] $ /opt/apache-maven-2.2.1/bin/mvn -f src/pom.xml -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions,proxy,printing,secJdbcJndiTest clean install -DconfigDirectory=../../../data
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Feature Service Module
[INFO] Web Coverage Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] Security UI Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Community Space
[INFO] Printing Module
[INFO] HTTP Proxy Extension
[INFO] GeoServer Web Application
[INFO] GeoServer Extensions
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Modules
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] Building GeoServer
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5800] GeoServer won't parse relative external graphic locations in SE 1.1 styles
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 13.06.2013 @ 14:05:22 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-Jun-2013 14:59
[INFO] [GitCommitIdMojo] build.build.time = 13.06.2013 @ 14:59:42 UTC
[INFO] [GitCommitIdMojo] build.branch = 8114587c9502fbd7ad5653ea5a4cf8aeb0015e37
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8114587
[INFO] [GitCommitIdMojo] build.commit.id = 8114587c9502fbd7ad5653ea5a4cf8aeb0015e37
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5800] GeoServer won't parse relative external graphic locations in SE 1.1 styles
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geotools:gt-api:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-api:9-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-api/9-SNAPSHOT/gt-api-9-20130612.060942-67.pom
[INFO] snapshot org.geotools:gt-main:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-main:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:library:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:library:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:modules:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:geotools:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:geotools:9-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/geotools/9-SNAPSHOT/geotools-9-20130612.060802-69.pom
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geotools:modules:pom:null
Reason: Cannot find parent: org.geotools:geotools for project: org.geotools:modules:pom:null for project org.geotools:modules:pom:null
[INFO] Total time: 11 seconds
[INFO] Finished at: Thu Jun 13 14:59:45 UTC 2013
[INFO] Final Memory: 36M/364M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/140/changes&gt;
