See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/94/changes>
Changes:
[riniangreani] GEOS-5693: Make app-schema joining default behaviour.
[riniangreani] GEOT-4417: App-schema joining with toXlinkHref results in some missing
[riniangreani] Test for GEOT-4460: Using functions in linkElement causes WMS error
[riniangreani] Remove Boolean type in app-schema test fixture as it's not recognized in Oracle.
[...truncated 33007 lines...]
at org.geoserver.test.AbstractAppSchemaTestSupport.get(AbstractAppSchemaTestSupport.java:188)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1185)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1149)
at org.geoserver.test.AbstractAppSchemaTestSupport.getAsDOM(AbstractAppSchemaTestSupport.java:214)
at org.geoserver.test.PropertySelectionTest.testGetFeatureInvalidName(PropertySelectionTest.java:126)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
at org.junit.rules.RunRules.evaluate(RunRules.java:18)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
Caused by: java.lang.IllegalArgumentException: Could not find working property accessor for attribute (DOESNT_EXIST) in object (SimpleFeatureImpl:MappedFeatureNoId=[SimpleFeatureImpl.Attribute: LOC_ACC<LOC_ACC id=>=200.0, SimpleFeatureImpl.Attribute: SHAPE<SHAPE id=>=POINT (-23.6701 133.8855), SimpleFeatureImpl.Attribute: ID<ID id=>=mf1, SimpleFeatureImpl.Attribute: GEOLOGIC_UNIT_ID<GEOLOGIC_UNIT_ID id=>=gu.25699])
at org.geotools.filter.AttributeExpressionImpl.evaluate(AttributeExpressionImpl.java:268)
at org.geotools.filter.AttributeExpressionImpl.evaluate(AttributeExpressionImpl.java:231)
at org.geotools.data.complex.DataAccessMappingFeatureIterator.getValues(DataAccessMappingFeatureIterator.java:456)
at org.geotools.data.complex.DataAccessMappingFeatureIterator.setAttributeValue(DataAccessMappingFeatureIterator.java:501)
at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:981)
... 66 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.793 sec
Running org.geoserver.test.SRSReprojectionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.308 sec
Running org.geoserver.test.Observation_2_0_WfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.01 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.502 sec
Running org.geoserver.test.BBox3DTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.886 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.75 sec
Running org.geoserver.test.MeasureTypeBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.429 sec
Running org.geoserver.test.MappingNameTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.902 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.85 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.991 sec
Running org.geoserver.test.GUChainNoIDMFTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.554 sec
Running org.geoserver.test.Gsml30WfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.622 sec
Running org.geoserver.test.DuplicatePropertiesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.487 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.603 sec
Running org.geoserver.test.PolymorphismInlineWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.434 sec
Running org.geoserver.test.FeatureGML32Test
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.723 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.937 sec
Running org.geoserver.test.SecondaryNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.756 sec
Running org.geoserver.test.InvalidColumnTest
06 May 09:01:08 ERROR [geoserver.ows] -
java.lang.RuntimeException: Error applying mapping with targetAttribute gml:name[4]
at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:994)
at org.geotools.data.complex.AbstractMappingFeatureIterator.next(AbstractMappingFeatureIterator.java:280)
at org.geotools.feature.collection.BridgeIterator.next(BridgeIterator.java:31)
at org.geotools.feature.collection.BridgeIterator.next(BridgeIterator.java:18)
at org.geotools.xml.Encoder.encode(Encoder.java:703)
at org.geotools.xml.Encoder.encode(Encoder.java:588)
at org.geoserver.wfs.xml.GML3OutputFormat.encode(GML3OutputFormat.java:270)
at org.geoserver.wfs.xml.GML3OutputFormat.complexFeatureStreamIntercept(GML3OutputFormat.java:292)
at org.geoserver.wfs.xml.GML3OutputFormat.write(GML3OutputFormat.java:252)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:190)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:919)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1354)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1373)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1308)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:920)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:903)
at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:888)
at org.geoserver.test.InvalidColumnTest.testGetFeature(InvalidColumnTest.java:30)
Caused by: java.lang.IllegalArgumentException: Could not find working property accessor for attribute (DESCRIPTIO) in object (SimpleFeatureImpl:InvalidColumnGeologicUnit=[SimpleFeatureImpl.Attribute: NAME<NAME id=gu.93>=Yaugher Volcanic Group, SimpleFeatureImpl.Attribute: CODE<CODE id=gu.93>=-Py, SimpleFeatureImpl.Attribute: URN<URN id=gu.93>=urn:x-test:GeologicUnit:16777549126931093, SimpleFeatureImpl.Attribute: DESCRIPTION<DESCRIPTION id=gu.93>=Olivine basalt, tuff, microgabbro, minor sedimentary rocks])
... 66 more
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.394 sec
Running org.geoserver.test.FeatureChainingWfsTest
06 May 09:01:10 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Feature type gsml:CompositionPart unknown
at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.checkTypeName(GetFeatureKvpRequestReader.java:385)
at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:143)
at org.geoserver.wfs.kvp.v2_0.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:39)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1412)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
at org.geoserver.test.FeatureChainingWfsTest.testGetFeature(FeatureChainingWfsTest.java:367)
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.427 sec
Running org.geoserver.test.SRSWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.045 sec
Results :
Tests in error:
testGetMapOutcropCharacter(org.geoserver.test.WmsGetMapTest)
testGetMapOutcropCharacterReprojection(org.geoserver.test.WmsGetMapTest)
testGetMapAfterWFS(org.geoserver.test.WmsGetMapTest)
Tests run: 118, Failures: 0, Errors: 3, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[INFO] Total time: 24 minutes 49 seconds
[INFO] Finished at: Mon May 06 09:01:16 UTC 2013
[INFO] Final Memory: 79M/367M
