[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.4.x-nightly #8
See <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/8/&gt;
Started by timer
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson2268339946699712365.sh
+ ver=2.4.x
+ dist=/var/www/html/geoserver/2.4.x
+ date +%Y-%m-%d
+ datestamp=2013-08-27
+ mvn=/opt/apache-maven-2.2.1/bin/mvn
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=8 -P release,communityRelease clean install
[INFO] Scanning for projects...
Process leaked file descriptors. See http://wiki.hudson-ci.org/display/HUDSON/Spawning+processes+from+build for more information
See <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/9/&gt;
[...truncated 2575 lines...]
[INFO] Excluding org.geoserver:platform:jar:2.4-SNAPSHOT from the shaded jar.
[INFO] Excluding org.springframework:spring-webmvc:jar:3.1.1.RELEASE from the shaded jar.
[INFO] Excluding org.springframework:spring-context-support:jar:3.1.1.RELEASE from the shaded jar.
[INFO] Excluding org.springframework:spring-web:jar:3.1.1.RELEASE from the shaded jar.
[INFO] Excluding javax.servlet:servlet-api:jar:2.5 from the shaded jar.
[INFO] Excluding javax.media:jai_core:jar:1.1.3 from the shaded jar.
[INFO] Excluding javax.media:jai_codec:jar:1.1.3 from the shaded jar.
[INFO] Excluding javax.media:jai_imageio:jar:1.1 from the shaded jar.
[INFO] Excluding org.geotools:gt-api:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding com.vividsolutions:jts:jar:1.13 from the shaded jar.
[INFO] Excluding org.geotools:gt-referencing:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding java3d:vecmath:jar:1.3.2 from the shaded jar.
[INFO] Excluding commons-pool:commons-pool:jar:1.5.3 from the shaded jar.
[INFO] Excluding org.geotools:gt-metadata:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-opengis:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding net.java.dev.jsr-275:jsr-275:jar:1.0-beta-2 from the shaded jar.
[INFO] Excluding jgridshift:jgridshift:jar:1.0 from the shaded jar.
[INFO] Excluding org.geotools:gt-main:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding jdom:jdom:jar:1.0 from the shaded jar.
[INFO] Excluding org.geowebcache:gwc-core:jar:1.5.0-beta from the shaded jar.
[INFO] Excluding commons-collections:commons-collections:jar:3.1 from the shaded jar.
[INFO] Excluding commons-io:commons-io:jar:2.1 from the shaded jar.
[INFO] Excluding commons-dbcp:commons-dbcp:jar:1.3 from the shaded jar.
[INFO] Excluding com.h2database:h2:jar:1.1.119 from the shaded jar.
[INFO] Excluding log4j:log4j:jar:1.2.14 from the shaded jar.
[INFO] Excluding org.springframework:spring-jdbc:jar:3.1.1.RELEASE from the shaded jar.
[INFO] Excluding org.springframework:spring-tx:jar:3.1.1.RELEASE from the shaded jar.
[INFO] Including commons-httpclient:commons-httpclient:jar:3.1 in the shaded jar.
[INFO] Including commons-codec:commons-codec:jar:1.2 in the shaded jar.
[INFO] Excluding org.owasp.encoder:encoder:jar:1.1 from the shaded jar.
[INFO] Excluding org.geotools.ogc:net.opengis.ows:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.ogc:org.w3.xlink:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.eclipse.emf:common:jar:2.6.0 from the shaded jar.
[INFO] Excluding org.eclipse.emf:ecore:jar:2.6.1 from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-ows:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-filter:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-coverage:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding it.geosolutions.imageio-ext:imageio-ext-tiff:jar:1.1.7 from the shaded jar.
[INFO] Excluding it.geosolutions.imageio-ext:imageio-ext-utilities:jar:1.1.7 from the shaded jar.
[INFO] Excluding org.jaitools:jt-zonalstats:jar:1.3.1 from the shaded jar.
[INFO] Excluding org.jaitools:jt-utils:jar:1.3.1 from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-core:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-graph:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding picocontainer:picocontainer:jar:1.2 from the shaded jar.
[INFO] Excluding xml-apis:xml-apis:jar:1.0.b2 from the shaded jar.
[INFO] Excluding commons-jxpath:commons-jxpath:jar:1.3 from the shaded jar.
[INFO] Excluding org.eclipse.xsd:xsd:jar:2.6.0 from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-gml2:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-gml3:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding xpp3:xpp3:jar:1.1.3.4.O from the shaded jar.
[INFO] Excluding net.sf.json-lib:json-lib:jar:jdk15:2.2.3 from the shaded jar.
[INFO] Excluding commons-beanutils:commons-beanutils:jar:1.7.0 from the shaded jar.
[INFO] Excluding net.sf.ezmorph:ezmorph:jar:1.0.6 from the shaded jar.
[INFO] Excluding commons-digester:commons-digester:jar:1.7 from the shaded jar.
[INFO] Excluding commons-fileupload:commons-fileupload:jar:1.2.1 from the shaded jar.
[INFO] Excluding commons-validator:commons-validator:jar:1.1.4 from the shaded jar.
[INFO] Excluding org.freemarker:freemarker:jar:2.3.18 from the shaded jar.
[INFO] Excluding oro:oro:jar:2.0.8 from the shaded jar.
[INFO] Excluding org.geotools:gt-cql:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-validation:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-data:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-jdbc:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-property:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-epsg-hsql:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding hsqldb:hsqldb:jar:1.8.0.7 from the shaded jar.
[INFO] Excluding org.geotools:gt-wms:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-xml:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.apache.xml:xml-commons-resolver:jar:1.2 from the shaded jar.
[INFO] Excluding org.geotools:gt-render:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-sld:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding com.thoughtworks.xstream:xstream:jar:1.4.3 from the shaded jar.
[INFO] Excluding xmlpull:xmlpull:jar:1.1.3.1 from the shaded jar.
[INFO] Excluding xpp3:xpp3_min:jar:1.1.4c from the shaded jar.
[INFO] Excluding org.geotools:gt-imagemosaic:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.jdbc:gt-jdbc-h2:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.opengeo:geodb:jar:0.7-RC2 from the shaded jar.
[INFO] Excluding net.sourceforge.hatbox:hatbox:jar:1.0.b7 from the shaded jar.
[INFO] Excluding org.geotools.jdbc:gt-jdbc-oracle:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.jdbc:gt-jdbc-postgis:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding postgresql:postgresql:jar:8.4-701.jdbc3 from the shaded jar.
[INFO] Excluding org.geotools:gt-shapefile:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-geotiff:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-transform:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding it.geosolutions.imageio-ext:imageio-ext-streams:jar:1.1.7 from the shaded jar.
[INFO] Excluding org.geotools:gt-image:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.jaitools:jt-vectorbinarize:jar:1.3.1 from the shaded jar.
[INFO] Excluding net.sf.ehcache:ehcache:jar:1.6.2 from the shaded jar.
[INFO] Excluding org.springframework.security:spring-security-web:jar:3.1.0.RELEASE from the shaded jar.
[INFO] Excluding org.springframework.security:spring-security-config:jar:3.1.0.RELEASE from the shaded jar.
[INFO] Excluding org.jasypt:jasypt:jar:1.8 from the shaded jar.
[INFO] Excluding org.bouncycastle:bcprov-jdk14:jar:1.46 from the shaded jar.
[INFO] Excluding org.restlet:org.restlet:jar:1.0.8 from the shaded jar.
[INFO] Excluding org.restlet:org.restlet.ext.freemarker:jar:1.0.8 from the shaded jar.
[INFO] Excluding org.restlet:org.restlet.ext.spring:jar:1.0.8 from the shaded jar.
[INFO] Excluding com.noelios.restlet:com.noelios.restlet.ext.servlet:jar:1.0.8 from the shaded jar.
[INFO] Excluding com.noelios.restlet:com.noelios.restlet:jar:1.0.8 from the shaded jar.
[INFO] Excluding org.codehaus.jettison:jettison:jar:1.0.1 from the shaded jar.
[INFO] Excluding stax:stax-api:jar:1.0.1 from the shaded jar.
[INFO] Excluding org.geoserver:wfs:jar:2.4-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.ogc:net.opengis.wfs:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.ogc:net.opengis.fes:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-wfs:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-fes:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geoserver:wms:jar:2.4-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geoserver:wcs:jar:2.4-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-arcgrid:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding it.geosolutions.imageio-ext:imageio-ext-arcgrid:jar:1.1.7 from the shaded jar.
[INFO] Excluding org.geotools:gt-gtopo30:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-svg:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-transcoder:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-awt-util:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-util:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-bridge:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-anim:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-dom:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-css:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-ext:jar:1.7 from the shaded jar.
[INFO] Excluding xml-apis:xml-apis-ext:jar:1.3.04 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-xml:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-parser:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-svg-dom:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-gvt:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-script:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-svggen:jar:1.7 from the shaded jar.
[INFO] Excluding org.geotools:gt-wfs:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-process:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding com.lowagie:itext:jar:2.1.5 from the shaded jar.
[INFO] Excluding org.geotools:gt-process-raster:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.jaitools:jt-rangelookup:jar:1.3.1 from the shaded jar.
[INFO] Excluding org.jaitools:jt-contour:jar:1.3.1 from the shaded jar.
[INFO] Excluding org.jaitools:jt-attributeop:jar:1.3.1 from the shaded jar.
[INFO] Excluding org.jaitools:jt-vectorize:jar:1.3.1 from the shaded jar.
[INFO] Excluding org.geotools:gt-process-feature:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-grid:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geoscript:geoscript-js:jar:1.0.0 from the shaded jar.
[INFO] Excluding org.mozilla:rhino:jar:1.7R4 from the shaded jar.
[INFO] Excluding jline:jline:jar:0.9.94 from the shaded jar.
[INFO] Excluding org.geotools:gt-process-geometry:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.jdbc:gt-jdbc-mysql:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding mysql:mysql-connector-java:jar:5.1.17 from the shaded jar.
[INFO] Excluding org.geotools.jdbc:gt-jdbc-spatialite:jar:9.0 from the shaded jar.
[INFO] Excluding org.xerial:sqlite-jdbc-spatialite:jar:3.7.2-2.4 from the shaded jar.
[INFO] Excluding org.geotools:gt-swing:jar:9.0 from the shaded jar.
[INFO] Excluding com.miglayout:miglayout:jar:swing:3.7 from the shaded jar.
[INFO] Attaching shaded artifact.
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/js/target/script-js-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-js/2.4-SNAPSHOT/script-js-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/js/target/script-js-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-js/2.4-SNAPSHOT/script-js-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/js/target/script-js-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-js/2.4-SNAPSHOT/script-js-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/js/target/script-js-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-js/2.4-SNAPSHOT/script-js-2.4-SNAPSHOT-test-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/js/target/shaded-artifact-2.4-SNAPSHOT-remoteconsole.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-js/2.4-SNAPSHOT/script-js-2.4-SNAPSHOT-remoteconsole.jar
[INFO] Building Groovy Scripting Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/target&gt;
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5689] Reloading configuration with workspace specific settings results in exception
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 24.08.2013 @ 12:38:27 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 28-Aug-2013 03:46
[INFO] [GitCommitIdMojo] build.build.time = 28.08.2013 @ 03:54:34 UTC
[INFO] [GitCommitIdMojo] build.branch = 8e7899afbb12ec51b543b4de7097241e219f1e74
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8e7899a
[INFO] [GitCommitIdMojo] build.commit.id = 8e7899afbb12ec51b543b4de7097241e219f1e74
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5689] Reloading configuration with workspace specific settings results in exception
[INFO] snapshot org.geoscript:geoscript-groovy:1.2-SNAPSHOT: checking for updates from osgeo
[INFO] [groovy:generateStubs {execution: default}]
[INFO] Generated 6 Java stubs
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/resources&gt;
[INFO] Compiling 9 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/target/generated-sources/groovy-stubs/main/geoserver/catalog/Layer.java&gt;:\[30,23\] package geoscript.layer does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/target/generated-sources/groovy-stubs/main/geoserver/catalog/Store.java&gt;:\[35,27\] package geoscript.workspace does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/target/generated-sources/groovy-stubs/main/geoserver/catalog/Layer.java&gt;:\[30,75\] package geoscript.layer does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/target/generated-sources/groovy-stubs/main/geoserver/catalog/Store.java&gt;:\[35,91\] package geoscript.workspace does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[64,34\] package geoscript.process does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[79,34\] package geoscript.process does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[93,24\] package geoscript.geom does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[96,28\] package geoscript.geom does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[99,29\] package geoscript.layer does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[112,37\] package geoscript.geom does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[114,26\] package geoscript.geom does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[116,42\] package geoscript.geom does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[118,26\] package geoscript.geom does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[120,43\] package geoscript.layer does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[122,27\] package geoscript.layer does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[124,43\] package geoscript.layer does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyWpsHook.java&gt;:\[126,27\] package geoscript.layer does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyFunctionHook.java&gt;:\[30,30\] package geoscript.geom does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyFunctionHook.java&gt;:\[40,44\] package geoscript.geom does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/ws/src/community/script/groovy/src/main/java/org/geoserver/script/groovy/GroovyFunctionHook.java&gt;:\[41,32\] package geoscript.geom does not exist
[INFO] 20 errors
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 9 minutes 3 seconds
[INFO] Finished at: Wed Aug 28 03:55:48 UTC 2013
[INFO] Final Memory: 111M/415M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.4.x/geoserver-2.4.x-2013-08-28-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-2.4.x-nightly/10/&gt;
