[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5353
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5353/&gt;
[...truncated 64655 lines...]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.282 sec
Running org.geoserver.wms.web.data.WMSAdminPageTest
09 Aug 04:23:07 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock8821096103942050820data&gt;
09 Aug 04:23:08 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock1656577766568015614data&gt;
09 Aug 04:23:09 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock6207409511150722332data&gt;
09 Aug 04:23:10 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock7981952906704040285data&gt;
09 Aug 04:23:11 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock5720264174360937814data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.033 sec
Running org.geoserver.wms.web.data.publish.WMSLayerConfigTest
09 Aug 04:23:12 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock5811590188956990175data&gt;
09 Aug 04:23:13 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock2256892205606473492data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock8337342058751644376data&gt;
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - debugging ----------------------------------------------
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form org.apache.wicket.markup.html.form.Form
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel org.geoserver.wms.web.publish.WMSLayerConfig [LayerInfoImpl[Ponds, resource:FeatureTypeInfoImpl[Ponds]]]
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:queryableEnabled org.apache.wicket.markup.html.form.CheckBox [true]
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles org.apache.wicket.markup.html.WebMarkupContainer
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:defaultStyle org.apache.wicket.markup.html.form.DropDownChoice [StyleInfoImpl[Ponds]]
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:defaultStyleLegendGraphic org.apache.wicket.markup.html.image.Image
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles org.apache.wicket.extensions.markup.html.form.palette.Palette []
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:recorder org.apache.wicket.extensions.markup.html.form.palette.component.Recorder
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:choices org.apache.wicket.extensions.markup.html.form.palette.component.Choices
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:selection org.apache.wicket.extensions.markup.html.form.palette.component.Selection
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:addButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:addButton:image org.apache.wicket.markup.html.image.Image
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:removeButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:removeButton:image org.apache.wicket.markup.html.image.Image
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:moveUpButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:moveUpButton:image org.apache.wicket.markup.html.image.Image
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:moveDownButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:moveDownButton:image org.apache.wicket.markup.html.image.Image
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:availableHeader org.apache.wicket.markup.html.basic.Label [Available Styles]
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:selectedHeader org.apache.wicket.markup.html.basic.Label [Selected Styles]
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:styles:renderingBuffer org.apache.wicket.markup.html.form.TextField
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:wmsPath org.apache.wicket.markup.html.form.TextField [/]
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds org.geoserver.wms.web.publish.LayerAuthoritiesAndIdentifiersPanel
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:authorityurls org.geoserver.wms.web.publish.AuthorityURLListEditor []
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:authorityurls:container org.apache.wicket.markup.html.WebMarkupContainer
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:authorityurls:container:table org.apache.wicket.markup.html.WebMarkupContainer
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:authorityurls:container:table:authorities org.apache.wicket.markup.html.list.ListView []
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:authorityurls:container:noURLs org.apache.wicket.markup.html.basic.Label [No authority URLs so far]
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:authorityurls:addURL org.apache.wicket.ajax.markup.html.form.AjaxButton
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:layerIdentifiers org.geoserver.wms.web.publish.LayerIdentifierListEditor []
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:layerIdentifiers:container org.apache.wicket.markup.html.WebMarkupContainer
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:layerIdentifiers:container:table org.apache.wicket.markup.html.WebMarkupContainer
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:layerIdentifiers:container:table:identifiers org.apache.wicket.markup.html.list.ListView []
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:layerIdentifiers:container:noIdentifiers org.apache.wicket.markup.html.basic.Label [No layer identifiers so far]
09 Aug 04:23:14 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:layerIdentifiers:addIdentifier org.apache.wicket.ajax.markup.html.form.AjaxButton
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.656 sec
Running org.geoserver.wms.web.data.StyleNewPageTest
09 Aug 04:23:14 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock8092296560524934780data&gt;
09 Aug 04:23:15 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock4485108094301273558data&gt;
09 Aug 04:23:16 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock8526628059471566661data&gt;
09 Aug 04:23:17 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock853290173351856380data&gt;
09 Aug 04:23:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock5933761962362749870data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.313 sec
Running org.geoserver.wms.web.data.StyleEditPageTest
09 Aug 04:23:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock4263941703596047369data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock3916386895022522262data&gt;
09 Aug 04:23:21 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock5315358807632551767data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.819 sec
Running org.geoserver.wms.web.publish.AttributionLayerConfigTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/./target/mock5273394648226764710data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.609 sec
Results :
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-wms/2.3-SNAPSHOT/web-wms-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-wms/2.3-SNAPSHOT/web-wms-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-wms/2.3-SNAPSHOT/web-wms-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-wms/2.3-SNAPSHOT/web-wms-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GWC UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = bb3d1d1f37f9c4aa1c84bb12a8eac67e199e50b3
[INFO] [GitCommitIdMojo] build.commit.id = bb3d1d1f37f9c4aa1c84bb12a8eac67e199e50b3
[INFO] [GitCommitIdMojo] build.commit.message.short = -GEOS-5226: CoverageAccessSettings and JAI page and global change events handling fix
[INFO] [GitCommitIdMojo] build.commit.time = 08.08.2012 @ 14:33:27 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = bb3d1d1
[INFO] [GitCommitIdMojo] build.commit.message.full = -GEOS-5226: CoverageAccessSettings and JAI page and global change events handling fix
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 09-Aug-2012 04:00
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 09.08.2012 @ 04:23:22 UTC
[INFO] Copying 9 resources
[INFO] Copying 21 resources
[INFO] Compiling 31 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/target/classes&gt;
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/resources&gt;
[INFO] Compiling 7 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/target/test-classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[7,25\] package org.mockito does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[7,0\] static import only from classes and interfaces
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[8,25\] package org.mockito does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[8,0\] static import only from classes and interfaces
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[9,25\] package org.mockito does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[9,0\] static import only from classes and interfaces
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[42,14\] cannot find symbol
symbol : method mock(java.lang.Class<org.geoserver.gwc.GWC>)
location: class org.geoserver.gwc.web.layer.LayerEditCacheOptionsTabPanelInfoTest
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[46,8\] cannot find symbol
symbol : method when(org.geoserver.gwc.config.GWCConfig)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[48,35\] cannot find symbol
symbol : method mock(java.lang.Class<org.geoserver.catalog.FeatureTypeInfo>)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[49,8\] cannot find symbol
symbol : method when(java.lang.String)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[51,16\] cannot find symbol
symbol : method mock(java.lang.Class<org.geoserver.catalog.LayerInfo>)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[52,8\] cannot find symbol
symbol : method when(org.geoserver.catalog.ResourceInfo)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[54,8\] cannot find symbol
symbol : method when(org.geoserver.catalog.MetadataMap)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[83,39\] cannot find symbol
symbol : method mock(java.lang.Class<org.geoserver.gwc.layer.GeoServerTileLayer>)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[86,8\] cannot find symbol
symbol : method when(org.geoserver.gwc.layer.GeoServerTileLayerInfo)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[87,30\] cannot find symbol
symbol : method same(org.geoserver.catalog.LayerInfo)
[INFO] Total time: 22 minutes 57 seconds
[INFO] Finished at: Thu Aug 09 04:23:26 UTC 2012
[INFO] Final Memory: 60M/268M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5354/changes&gt;
Changes:
[David Winslow] Add missing test dependency for web/gwc
[...truncated 89081 lines...]
<gml:coord>
<gml:X>597086.9686143089</gml:X>
<gml:Y>4921789.551205</gml:Y>
</gml:coord>
</gml:Box>
</gml:boundedBy>
<feature:z_the_geom>
<gml:MultiPolygon srsName="http://www.opengis.net/gml/srs/epsg.xml#26713&quot;&gt;
<gml:polygonMember>
<gml:Polygon>
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>592316.9379796328,4921789.551205 595825.0954050707,4921744.536515899 595885.9596931553,4921724.645000904 595988.6597380087,4921687.164865309 596085.2476595924,4921639.762469891 596199.3035518276,4921572.496462965 596425.0407301437,4921395.970557282 596646.8773303393,4921175.924634823 596705.3044231973,4921085.024251698 596895.7087137242,4920764.209535123 597037.3181371056,4920411.356964448 597086.9686143089,4920134.155276274 597086.9455551769,4920123.465548163 595404.9389344064,4916851.195066947 595299.9499316034,4916886.386015123 595162.2497092936,4916933.814845423 594983.526128624,4917022.501919034 594829.906966761,4917102.010213899 594395.0453582691,4917391.676438842 594318.2555423079,4917440.593210369 594052.0932835294,4917582.785221043 593703.9205438099,4917824.291862512 593327.876386339,4918204.019530202 592902.7306171365,4918762.450187511 592799.5541783689,4918932.025310009 592746.4663403123,4919027.503578438 592681.9715953676,4919129.097605954 592425.6305890534,4919588.921377501 592354.4073250518,4919747.786211425 592321.8954023286,4919852.413886508 592250.9171658278,4920477.809486801 592252.310983779,4920771.012968304 592264.8066111131,4921269.605086448 592316.9379796328,4921789.551205</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</gml:polygonMember>
</gml:MultiPolygon>
</feature:z_the_geom>
<feature:z_cat>3</feature:z_cat>
<feature:count>23</feature:count>
<feature:min>32.0</feature:min>
<feature:max>81.0</feature:max>
<feature:sum>1331.0</feature:sum>
<feature:avg>57.869565217391305</feature:avg>
<feature:stddev>15.120686514855372</feature:stddev>
</feature:restricted>
</gml:featureMember>
</wfs:FeatureCollection>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.618 sec
Running org.geoserver.wps.gs.CropCoverageTest
09 Aug 15:07:32 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock3053061644209412366data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.766 sec
Running org.geoserver.wps.UniqueProcessNamesTest
09 Aug 15:07:33 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock2281424145896127099data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.403 sec
Running org.geoserver.wps.DescribeProcessTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock2085888452089083690data&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.837 sec
Running org.geoserver.wps.gs.RasterAsPointCollectionTest
09 Aug 15:07:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock1721858044335183604data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.733 sec
Running org.geoserver.wps.gs.ClipProcessTest
09 Aug 15:07:35 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock657341215349811596data&gt;
<wfs:FeatureCollection xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:feature="http://www.openplans.org/topp&quot; xmlns:wfs="http://www.opengis.net/wfs&quot;&gt;&lt;gml:boundedBy&gt;&lt;gml:Box srsName="http://www.opengis.net/gml/srs/epsg\.xml\#4326&quot;&gt;&lt;gml:coord&gt;&lt;gml:X&gt;\-91\.516129&lt;/gml:X&gt;&lt;gml:Y&gt;36\.986771000000005&lt;/gml:Y&gt;&lt;/gml:coord&gt;&lt;gml:coord&gt;&lt;gml:X&gt;\-87\.507889&lt;/gml:X&gt;&lt;gml:Y&gt;42\.50936100000001&lt;/gml:Y&gt;&lt;/gml:coord&gt;&lt;/gml:Box&gt;&lt;/gml:boundedBy&gt;&lt;gml:featureMember&gt;&lt;feature:states fid="states.1"><gml:boundedBy><gml:Box srsName="http://www.opengis.net/gml/srs/epsg\.xml\#4326&quot;&gt;&lt;gml:coord&gt;&lt;gml:X&gt;\-91\.516129&lt;/gml:X&gt;&lt;gml:Y&gt;40\.0&lt;/gml:Y&gt;&lt;/gml:coord&gt;&lt;gml:coord&gt;&lt;gml:X&gt;\-90\.0&lt;/gml:X&gt;&lt;gml:Y&gt;42\.50936100000001&lt;/gml:Y&gt;&lt;/gml:coord&gt;&lt;/gml:Box&gt;&lt;/gml:boundedBy&gt;&lt;feature:the\_geom&gt;&lt;gml:MultiPolygon srsName="http://www.opengis.net/gml/srs/epsg\.xml\#4326&quot;&gt;&lt;gml:polygonMember&gt;&lt;gml:Polygon&gt;&lt;gml:outerBoundaryIs&gt;&lt;gml:LinearRing&gt;&lt;gml:coordinates&gt;\-91\.48342924966074,40\.0 -91.487289,40.005753 -91.504005,40.066711 -91.516129,40.134544000000005 -91.506546,40.200458999999995 -91.498932,40.25137699999999 -91.486694,40.309624000000014 -91.448593,40.371902000000006 -91.418816,40.386875 -91.385757,40.392360999999994 -91.372757,40.40298799999999 -91.385399,40.44725 -91.374794,40.50365400000001 -91.382103,40.52849599999999 -91.412872,40.54799299999999 -91.411118,40.572970999999995 -91.37561,40.60343900000001 -91.262062,40.639545 -91.214912,40.64381800000001 -91.162498,40.65631099999999 -91.129158,40.68214800000001 -91.119987,40.70540199999999 -91.092751,40.76154700000001 -91.088905,40.833729000000005 -91.04921,40.87958499999999 -90.983276,40.92392699999999 -90.960709,40.950503999999995 -90.954651,41.07036199999999 -90.957787,41.10435899999999 -90.990341,41.14437100000001 -91.018257,41.16582500000001 -91.05632,41.17625799999999 -91.101524,41.23152200000001 -91.102348,41.267818000000005 -91.07328,41.334895999999986 -91.055786,41.40137899999999 -91.027489,41.423508 -91.000694,41.431084 -90.949654,41.421234 -90.844139,41.44462200000001 -90.7799,41.449820999999986 -90.708214,41.450062 -90.658791,41.46231800000001 -90.6007,41.50958600000001 -90.54084,41.52597 -90.454994,41.527546 -90.434967,41.543578999999994 -90.423004,41.567272 -90.348366,41.586849 -90.339348,41.60279800000001 -90.341133,41.64909 -90.326027,41.722736 -90.304886,41.75646599999999 -90.25531,41.78173799999999 -90.195839,41.80613700000001 -90.154518,41.93077500000001 -90.14267,41.98396299999999 -90.150536,42.03342799999999 -90.168098,42.06104300000001 -90.166649,42.103745 -90.176086,42.12050199999999 -90.191574,42.12268800000001 -90.230934,42.15972099999999 -90.323601,42.19731899999999 -90.367729,42.21020899999999 -90.407173,42.24264500000001 -90.417984,42.263924 -90.427681,42.340633 -90.441597,42.360073 -90.491043,42.38878299999999 -90.563583,42.42183700000001 -90.605827,42.46055999999999 -90.648346,42.47564299999999 -90.651772,42.494698 -90.638329,42.50936100000001 -90.419975,42.508362000000005 -90.0,42.50476298296556 -90.0,40.0 -91.48342924966074,40.0</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></feature:the_geom><feature:STATE_NAME>Illinois</feature:STATE_NAME><feature:STATE_FIPS>17</feature:STATE_FIPS><feature:SUB_REGION>E N Cen</feature:SUB_REGION><feature:STATE_ABBR>IL</feature:STATE_ABBR><feature:LAND_KM>143986.61</feature:LAND_KM><feature:WATER_KM>1993.335</feature:WATER_KM><feature:PERSONS>1.1430602E7</feature:PERSONS><feature:FAMILIES>2924880.0</feature:FAMILIES><feature:HOUSHOLD>4202240.0</feature:HOUSHOLD><feature:MALE>5552233.0</feature:MALE><feature:FEMALE>5878369.0</feature:FEMALE><feature:WORKERS>4199206.0</feature:WORKERS><feature:DRVALONE>3741715.0</feature:DRVALONE><feature:CARPOOL>652603.0</feature:CARPOOL><feature:PUBTRANS>538071.0</feature:PUBTRANS><feature:EMPLOYED>5417967.0</feature:EMPLOYED><feature:UNEMPLOY>385040.0</feature:UNEMPLOY><feature:SERVICE>1360159.0</feature:SERVICE><feature:MANUAL>828906.0</feature:MANUAL><feature:P_MALE>0.486</feature:P_MALE><feature:P_FEMALE>0.514</feature:P_FEMALE><feature:SAMP_POP>1747776.0</feature:SAMP_POP></feature:states></gml:featureMember></wfs:FeatureCollection>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.529 sec
Running org.geoserver.wps.gs.RasterZonalStatsTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock1026140493314314504data&gt;
09 Aug 15:07:37 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock1844701223278961644data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.342 sec
Results :
Tests run: 119, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service GUI
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target&gt;
[INFO] [GitCommitIdMojo] build.branch = 0ec6f0b084157b77ec3a868938dfec1a6782884a
[INFO] [GitCommitIdMojo] build.commit.id = 0ec6f0b084157b77ec3a868938dfec1a6782884a
[INFO] [GitCommitIdMojo] build.commit.message.short = Add missing test dependency for web/gwc
[INFO] [GitCommitIdMojo] build.commit.time = 09.08.2012 @ 14:03:58 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 0ec6f0b
[INFO] [GitCommitIdMojo] build.commit.message.full = Add missing test dependency for web/gwc
[INFO] [GitCommitIdMojo] build.commit.user.email = dwinslow@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = David Winslow
[INFO] [GitCommitIdMojo] build.timestamp = 09-Aug-2012 14:36
[INFO] [GitCommitIdMojo] build.build.time = 09.08.2012 @ 15:07:39 UTC
[INFO] Copying 11 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/src/main/resources&gt;
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/src/test/resources&gt;
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wps.web.WPSExecuteTransformerTest
Aug 9, 2012 3:07:45 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Aug 9, 2012 3:07:46 PM org.geoserver.platform.GeoServerExtensions checkContext
[Fatal Error] :2:1: Content is not allowed in prolog.
Aug 9, 2012 3:07:48 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.539 sec
Running org.geoserver.wps.web.WPSAdminPageTest
09 Aug 15:07:50 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/./target/mock700371023940165083data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.9 sec
Running org.geoserver.wps.web.WPSRequestBuilderTest
09 Aug 15:08:01 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/./target/mock5509187106664599748data&gt;
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.284 sec <<< FAILURE!
Results :
Failed tests:
  testJTSAreaWorkflow(org.geoserver.wps.web.WPSRequestBuilderTest)
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 31 minutes 43 seconds
[INFO] Finished at: Thu Aug 09 15:08:02 UTC 2012
[INFO] Final Memory: 76M/229M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5355/changes&gt;
Changes:
[jdeolive] make wms describeLayer strip prefix for workspace
[jdeolive] GEOS-5016, fixing test case based on assumptions of workspace != namespace
[...truncated 89142 lines...]
<gml:coord>
</gml:coord>
</gml:Box>
</gml:boundedBy>
<gml:polygonMember>
<gml:Polygon>
<gml:LinearRing>
</gml:LinearRing>
</gml:Polygon>
</gml:MultiPolygon>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.614 sec
09 Aug 17:07:30 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock2534812202515436121data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.681 sec
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock6457915139433092805data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.398 sec
09 Aug 17:07:31 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock749284743495440476data&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.7 sec
09 Aug 17:07:32 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock1880888995835026625data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.638 sec
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock6629169164183696171data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.027 sec
09 Aug 17:07:33 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock2935481805349179488data&gt;
09 Aug 17:07:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock7430777400659834980data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.513 sec
Results :
[INFO] [GitCommitIdMojo] build.branch = 1f26fafb70ae9c21a0073d5714ae3acc8c9b1ee5
[INFO] [GitCommitIdMojo] build.commit.id = 1f26fafb70ae9c21a0073d5714ae3acc8c9b1ee5
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5016, fixing test case based on assumptions of workspace != namespace
[INFO] [GitCommitIdMojo] build.commit.time = 09.08.2012 @ 16:26:15 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 1f26faf
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5016, fixing test case based on assumptions of workspace != namespace
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.timestamp = 09-Aug-2012 16:36
[INFO] [GitCommitIdMojo] build.build.time = 09.08.2012 @ 17:07:36 UTC
T E S T S
Aug 9, 2012 5:07:43 PM org.geoserver.platform.GeoServerExtensions checkContext
Aug 9, 2012 5:07:45 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.584 sec
09 Aug 17:07:47 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/./target/mock3742854435359844399data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.513 sec
09 Aug 17:07:57 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/./target/mock2638445427929530849data&gt;
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.353 sec <<< FAILURE!
Results :
Failed tests:
[INFO] Total time: 31 minutes 41 seconds
[INFO] Finished at: Thu Aug 09 17:07:59 UTC 2012
[INFO] Final Memory: 76M/246M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5356/&gt;
[...truncated 43895 lines...]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.header org.apache.wicket.markup.html.basic.Label [Settings]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [Global]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links:1:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links:1:link:link.label org.apache.wicket.markup.html.basic.Label [JAI]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links:1:link:link.icon org.apache.wicket.markup.html.image.Image
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links:2:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links:2:link:link.label org.apache.wicket.markup.html.basic.Label [Coverage Access]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:2:category.links:2:link:link.icon org.apache.wicket.markup.html.image.Image
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.Category@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.header org.apache.wicket.markup.html.basic.Label [Security]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [Settings]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:1:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:1:link:link.label org.apache.wicket.markup.html.basic.Label [Authentication]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:1:link:link.icon org.apache.wicket.markup.html.image.Image
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:2:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:2:link:link.label org.apache.wicket.markup.html.basic.Label [Passwords]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:2:link:link.icon org.apache.wicket.markup.html.image.Image
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:3 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:3:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:3:link:link.label org.apache.wicket.markup.html.basic.Label [Users, Groups, Roles]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:3:link:link.icon org.apache.wicket.markup.html.image.Image
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:4 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:4:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:4:link:link.label org.apache.wicket.markup.html.basic.Label [Data]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:4:link:link.icon org.apache.wicket.markup.html.image.Image
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:5 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:5:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:5:link:link.label org.apache.wicket.markup.html.basic.Label [Services]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path category:3:category.links:5:link:link.icon org.apache.wicket.markup.html.image.Image
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path standalone org.apache.wicket.markup.html.list.ListView []
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path feedback org.apache.wicket.markup.html.panel.FeedbackPanel
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path ajaxFeedbackImage org.apache.wicket.markup.html.image.Image
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path headerPanel org.apache.wicket.markup.html.WebMarkupContainer
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path dialog org.geoserver.web.wicket.GeoServerDialog
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form org.apache.wicket.markup.html.form.Form [org.geoserver.security.password.MasterPasswordConfig@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:providerName org.geoserver.security.web.passwd.MasterPasswordProviderChoice [default]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:changePassword org.apache.wicket.markup.html.link.Link [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: changePassword]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders org.geoserver.security.web.passwd.MasterPasswordProvidersPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: masterPasswordProviders]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:add org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: add]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:remove org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: remove]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table org.geoserver.security.web.SecurityNamedServicesPanel$SecurityNamedServiceTablePanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: table]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm org.apache.wicket.markup.html.form.Form [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: filterForm]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:filter org.apache.wicket.markup.html.form.TextField
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorTop]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 1 (out of 1 items)]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: listContainer]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: items]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3 org.apache.wicket.markup.repeater.Item [org.geoserver.security.password.URLMasterPasswordProviderConfig@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default URL master password provider]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectAllContainer]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorBottom]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: 0]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: pageLink]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: first]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: prev]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: next]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: last]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 1 (out of 1 items)]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedback]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedbackul]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:dialog org.geoserver.web.wicket.GeoServerDialog [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: content]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:masterPasswordProvidersHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: masterPasswordProvidersHelp]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies org.geoserver.security.web.passwd.PasswordPoliciesPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: passwordPolicies]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:add org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: add]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:remove org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: remove]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table org.geoserver.security.web.SecurityNamedServicesPanel$SecurityNamedServiceTablePanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: table]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm org.apache.wicket.markup.html.form.Form [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: filterForm]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:filter org.apache.wicket.markup.html.form.TextField
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorTop]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: listContainer]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: items]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default2]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default2]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default2]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [master]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [master]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [master]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectAllContainer]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorBottom]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: 0]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: pageLink]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: first]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: prev]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: next]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: last]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedback]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedbackul]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog org.geoserver.web.wicket.GeoServerDialog [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: content]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:passwordPoliciesHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: passwordPoliciesHelp]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:save org.apache.wicket.markup.html.form.SubmitLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: save]
10 Aug 06:37:00 INFO [tester.BaseWicketTester] - path form:cancel org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: cancel]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.074 sec
Running org.geoserver.security.web.data.EditDataAccessRulePageTest
10 Aug 06:37:00 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock5708907272284799346data&gt;
10 Aug 06:37:02 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock2344956343377016982data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock8285736834911017177data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.519 sec
Running org.geoserver.security.web.group.GroupListPageTest
10 Aug 06:37:03 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock2996338401519508862data&gt;
10 Aug 06:37:05 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock3745700053210751data&gt;
10 Aug 06:37:06 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock7147039465531434688data&gt;
10 Aug 06:37:07 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock4126865548734301261data&gt;
10 Aug 06:37:08 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock4658877147783093450data&gt;
10 Aug 06:37:09 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock1636499587737623670data&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.869 sec
Running org.geoserver.security.web.auth.AuthenticationPageTest
10 Aug 06:37:11 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock4333913229036025337data&gt;
10 Aug 06:37:13 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock7606345270830560317data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.02 sec
Results :
Failed tests:
  testRemove(org.geoserver.security.web.service.ServiceAccessRulePageTest)
Tests run: 93, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 13 minutes 53 seconds
[INFO] Finished at: Fri Aug 10 06:37:14 UTC 2012
[INFO] Final Memory: 55M/355M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5357/changes&gt;
Changes:
[Christian Mueller] Fix GEOS-5259
[jdeolive] GEOS-5261, fixing typo checking for fallback on rule name as legend title
[...truncated 89321 lines...]
<gml:coord>
</gml:coord>
</gml:Box>
</gml:boundedBy>
<gml:polygonMember>
<gml:Polygon>
<gml:LinearRing>
</gml:LinearRing>
</gml:Polygon>
</gml:MultiPolygon>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.087 sec
10 Aug 14:21:56 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock3740846381742599414data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.639 sec
10 Aug 14:21:57 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock1783839075740462404data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.404 sec
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock1984291909235182835data&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.671 sec
10 Aug 14:21:58 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock2013188143141508084data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.682 sec
10 Aug 14:21:59 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock1736335690798070370data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.567 sec
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock2965181607470449220data&gt;
10 Aug 14:22:01 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock6007532540823965578data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.569 sec
Results :
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 1f34aece371eaea6b195d1a7f2fe7b562b0b1baf
[INFO] [GitCommitIdMojo] build.commit.id = 1f34aece371eaea6b195d1a7f2fe7b562b0b1baf
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5261, fixing typo checking for fallback on rule name as legend title
[INFO] [GitCommitIdMojo] build.commit.time = 10.08.2012 @ 13:22:05 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 1f34aec
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5261, fixing typo checking for fallback on rule name as legend title
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 10-Aug-2012 13:50
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 10.08.2012 @ 14:22:02 UTC
[INFO] Copying 0 resource
T E S T S
Aug 10, 2012 2:22:08 PM org.geoserver.platform.GeoServerExtensions checkContext
Aug 10, 2012 2:22:11 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.745 sec
10 Aug 14:22:12 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/./target/mock7169598028381049177data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.685 sec
10 Aug 14:22:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/./target/mock1504781551678451039data&gt;
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 1.626 sec <<< FAILURE!
Results :
Failed tests:
[INFO] Total time: 31 minutes 35 seconds
[INFO] Finished at: Fri Aug 10 14:22:24 UTC 2012
[INFO] Final Memory: 77M/277M
On Fri, Aug 10, 2012 at 4:22 PM, Hudson <monitor@anonymised.com> wrote:
Failed tests:
Wondering if something is wrong with the build server, I’ve build wps a number of times during
the past two days, never seen this one
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5358/changes&gt;
Changes:
[Martin Davis] GEOS-5244 - Added request parameter name to WPS Request Builder
[...truncated 89135 lines...]
</gml:Box>
</gml:boundedBy>
<feature:z_the_geom>
<gml:MultiPolygon srsName="http://www.opengis.net/gml/srs/epsg.xml#26713&quot;&gt;
<gml:polygonMember>
<gml:Polygon>
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>592316.9379796328,4921789.551205 595825.0954050707,4921744.536515899 595885.9596931553,4921724.645000904 595988.6597380087,4921687.164865309 596085.2476595924,4921639.762469891 596199.3035518276,4921572.496462965 596425.0407301437,4921395.970557282 596646.8773303393,4921175.924634823 596705.3044231973,4921085.024251698 596895.7087137242,4920764.209535123 597037.3181371056,4920411.356964448 597086.9686143089,4920134.155276274 597086.9455551769,4920123.465548163 595404.9389344064,4916851.195066947 595299.9499316034,4916886.386015123 595162.2497092936,4916933.814845423 594983.526128624,4917022.501919034 594829.906966761,4917102.010213899 594395.0453582691,4917391.676438842 594318.2555423079,4917440.593210369 594052.0932835294,4917582.785221043 593703.9205438099,4917824.291862512 593327.876386339,4918204.019530202 592902.7306171365,4918762.450187511 592799.5541783689,4918932.025310009 592746.4663403123,4919027.503578438 592681.9715953676,4919129.097605954 592425.6305890534,4919588.921377501 592354.4073250518,4919747.786211425 592321.8954023286,4919852.413886508 592250.9171658278,4920477.809486801 592252.310983779,4920771.012968304 592264.8066111131,4921269.605086448 592316.9379796328,4921789.551205</gml:coordinates>
</gml:LinearRing>
</gml:Polygon>
</gml:MultiPolygon>
</feature:z_the_geom>
<feature:z_cat>3</feature:z_cat>
<feature:count>23</feature:count>
<feature:min>32.0</feature:min>
<feature:max>81.0</feature:max>
<feature:sum>1331.0</feature:sum>
<feature:avg>57.869565217391305</feature:avg>
<feature:stddev>15.120686514855372</feature:stddev>
</feature:restricted>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.606 sec
Running org.geoserver.wps.gs.CropCoverageTest
10 Aug 21:07:31 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock5415808423932548108data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.619 sec
Running org.geoserver.wps.UniqueProcessNamesTest
10 Aug 21:07:32 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock4173302289405788980data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.464 sec
Running org.geoserver.wps.DescribeProcessTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock4402509181080605683data&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.669 sec
Running org.geoserver.wps.gs.RasterAsPointCollectionTest
10 Aug 21:07:33 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock3378842490416698045data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.665 sec
Running org.geoserver.wps.gs.ClipProcessTest
10 Aug 21:07:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock6072744915521352785data&gt;
<wfs:FeatureCollection xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:feature="http://www.openplans.org/topp&quot; xmlns:wfs="http://www.opengis.net/wfs&quot;&gt;&lt;gml:boundedBy&gt;&lt;gml:Box srsName="http://www.opengis.net/gml/srs/epsg\.xml\#4326&quot;&gt;&lt;gml:coord&gt;&lt;gml:X&gt;\-91\.516129&lt;/gml:X&gt;&lt;gml:Y&gt;36\.986771000000005&lt;/gml:Y&gt;&lt;/gml:coord&gt;&lt;gml:coord&gt;&lt;gml:X&gt;\-87\.507889&lt;/gml:X&gt;&lt;gml:Y&gt;42\.50936100000001&lt;/gml:Y&gt;&lt;/gml:coord&gt;&lt;/gml:Box&gt;&lt;/gml:boundedBy&gt;&lt;gml:featureMember&gt;&lt;feature:states fid="states.1"><gml:boundedBy><gml:Box srsName="http://www.opengis.net/gml/srs/epsg\.xml\#4326&quot;&gt;&lt;gml:coord&gt;&lt;gml:X&gt;\-91\.516129&lt;/gml:X&gt;&lt;gml:Y&gt;40\.0&lt;/gml:Y&gt;&lt;/gml:coord&gt;&lt;gml:coord&gt;&lt;gml:X&gt;\-90\.0&lt;/gml:X&gt;&lt;gml:Y&gt;42\.50936100000001&lt;/gml:Y&gt;&lt;/gml:coord&gt;&lt;/gml:Box&gt;&lt;/gml:boundedBy&gt;&lt;feature:the\_geom&gt;&lt;gml:MultiPolygon srsName="http://www.opengis.net/gml/srs/epsg\.xml\#4326&quot;&gt;&lt;gml:polygonMember&gt;&lt;gml:Polygon&gt;&lt;gml:outerBoundaryIs&gt;&lt;gml:LinearRing&gt;&lt;gml:coordinates&gt;\-91\.48342924966074,40\.0 -91.487289,40.005753 -91.504005,40.066711 -91.516129,40.134544000000005 -91.506546,40.200458999999995 -91.498932,40.25137699999999 -91.486694,40.309624000000014 -91.448593,40.371902000000006 -91.418816,40.386875 -91.385757,40.392360999999994 -91.372757,40.40298799999999 -91.385399,40.44725 -91.374794,40.50365400000001 -91.382103,40.52849599999999 -91.412872,40.54799299999999 -91.411118,40.572970999999995 -91.37561,40.60343900000001 -91.262062,40.639545 -91.214912,40.64381800000001 -91.162498,40.65631099999999 -91.129158,40.68214800000001 -91.119987,40.70540199999999 -91.092751,40.76154700000001 -91.088905,40.833729000000005 -91.04921,40.87958499999999 -90.983276,40.92392699999999 -90.960709,40.950503999999995 -90.954651,41.07036199999999 -90.957787,41.10435899999999 -90.990341,41.14437100000001 -91.018257,41.16582500000001 -91.05632,41.17625799999999 -91.101524,41.23152200000001 -91.102348,41.267818000000005 -91.07328,41.334895999999986 -91.055786,41.40137899999999 -91.027489,41.423508 -91.000694,41.431084 -90.949654,41.421234 -90.844139,41.44462200000001 -90.7799,41.449820999999986 -90.708214,41.450062 -90.658791,41.46231800000001 -90.6007,41.50958600000001 -90.54084,41.52597 -90.454994,41.527546 -90.434967,41.543578999999994 -90.423004,41.567272 -90.348366,41.586849 -90.339348,41.60279800000001 -90.341133,41.64909 -90.326027,41.722736 -90.304886,41.75646599999999 -90.25531,41.78173799999999 -90.195839,41.80613700000001 -90.154518,41.93077500000001 -90.14267,41.98396299999999 -90.150536,42.03342799999999 -90.168098,42.06104300000001 -90.166649,42.103745 -90.176086,42.12050199999999 -90.191574,42.12268800000001 -90.230934,42.15972099999999 -90.323601,42.19731899999999 -90.367729,42.21020899999999 -90.407173,42.24264500000001 -90.417984,42.263924 -90.427681,42.340633 -90.441597,42.360073 -90.491043,42.38878299999999 -90.563583,42.42183700000001 -90.605827,42.46055999999999 -90.648346,42.47564299999999 -90.651772,42.494698 -90.638329,42.50936100000001 -90.419975,42.508362000000005 -90.0,42.50476298296556 -90.0,40.0 -91.48342924966074,40.0</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></feature:the_geom><feature:STATE_NAME>Illinois</feature:STATE_NAME><feature:STATE_FIPS>17</feature:STATE_FIPS><feature:SUB_REGION>E N Cen</feature:SUB_REGION><feature:STATE_ABBR>IL</feature:STATE_ABBR><feature:LAND_KM>143986.61</feature:LAND_KM><feature:WATER_KM>1993.335</feature:WATER_KM><feature:PERSONS>1.1430602E7</feature:PERSONS><feature:FAMILIES>2924880.0</feature:FAMILIES><feature:HOUSHOLD>4202240.0</feature:HOUSHOLD><feature:MALE>5552233.0</feature:MALE><feature:FEMALE>5878369.0</feature:FEMALE><feature:WORKERS>4199206.0</feature:WORKERS><feature:DRVALONE>3741715.0</feature:DRVALONE><feature:CARPOOL>652603.0</feature:CARPOOL><feature:PUBTRANS>538071.0</feature:PUBTRANS><feature:EMPLOYED>5417967.0</feature:EMPLOYED><feature:UNEMPLOY>385040.0</feature:UNEMPLOY><feature:SERVICE>1360159.0</feature:SERVICE><feature:MANUAL>828906.0</feature:MANUAL><feature:P_MALE>0.486</feature:P_MALE><feature:P_FEMALE>0.514</feature:P_FEMALE><feature:SAMP_POP>1747776.0</feature:SAMP_POP></feature:states></gml:featureMember></wfs:FeatureCollection>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.561 sec
Running org.geoserver.wps.gs.RasterZonalStatsTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock4820842775894647716data&gt;
10 Aug 21:07:35 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/./target/mock5545645725658513635data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.585 sec
Results :
Tests run: 119, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service GUI
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target&gt;
[INFO] [GitCommitIdMojo] build.branch = bcd4b097f5aad864942bc2b1ce6c665cf33b86e6
[INFO] [GitCommitIdMojo] build.commit.id = bcd4b097f5aad864942bc2b1ce6c665cf33b86e6
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5244 - Added request parameter name to WPS Request Builder
[INFO] [GitCommitIdMojo] build.commit.time = 10.08.2012 @ 20:20:51 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = bcd4b09
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5244 - Added request parameter name to WPS Request Builder
[INFO] [GitCommitIdMojo] build.commit.user.email = mdavis@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Martin Davis
[INFO] [GitCommitIdMojo] build.timestamp = 10-Aug-2012 20:36
[INFO] [GitCommitIdMojo] build.build.time = 10.08.2012 @ 21:07:37 UTC
[INFO] Copying 11 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/src/main/resources&gt;
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/src/test/resources&gt;
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wps.web.WPSExecuteTransformerTest
Aug 10, 2012 9:07:42 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
[Fatal Error] :2:1: Content is not allowed in prolog.
Aug 10, 2012 9:07:45 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.475 sec
Running org.geoserver.wps.web.WPSAdminPageTest
10 Aug 21:07:46 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/./target/mock7239781603794022123data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.912 sec
Running org.geoserver.wps.web.WPSRequestBuilderTest
10 Aug 21:07:57 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/./target/mock788340770609738333data&gt;
10 Aug 21:07:59 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/./target/mock6828986398603599838data&gt;
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 3.492 sec <<< FAILURE!
Results :
Failed tests:
  testJTSAreaWorkflow(org.geoserver.wps.web.WPSRequestBuilderTest)
Tests run: 5, Failures: 1, Errors: 0, Skipped: 0
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 31 minutes 42 seconds
[INFO] Finished at: Fri Aug 10 21:08:00 UTC 2012
[INFO] Final Memory: 77M/315M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5359/changes&gt;
