[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5692
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5692/changes&gt;
Changes:
[Christian Mueller] Temporary fix for GEOS-5353
[Christian Mueller] GSIP 82, reworking filter chains including the GUI
[Christian Mueller] CAS based on GSIP-82
[...truncated 32863 lines...]
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wps.web.WPSAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 17.704 sec
Running org.geoserver.wps.web.WPSExecuteTransformerTest
[Fatal Error] :2:1: Content is not allowed in prolog.
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.743 sec
Running org.geoserver.wps.web.WPSRequestBuilderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.786 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.3-SNAPSHOT/web-wps-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.3-SNAPSHOT/web-wps-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.3-SNAPSHOT/web-wps-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.3-SNAPSHOT/web-wps-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Layer Querying filter functions
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 33c536112631017a9d7565b0510320f80e71336c
[INFO] [GitCommitIdMojo] build.commit.id = 33c536112631017a9d7565b0510320f80e71336c
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge branch 'sec-filterchain', GSIP 82 and CAS
[INFO] [GitCommitIdMojo] build.commit.time = 14.12.2012 @ 13:23:26 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 33c5361
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge branch 'sec-filterchain', GSIP 82 and CAS
Conflicts:
  src/main/src/test/java/org/geoserver/security/GeoServerAnonymousAuthTest.java
[INFO] [GitCommitIdMojo] build.commit.user.email = christian.mueller@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Christian Mueller
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 14-Dec-2012 14:26
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 14.12.2012 @ 14:56:58 UTC
[INFO] Copying 0 resource
[INFO] Copying 2 resources
[INFO] Compiling 4 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/src/test/resources&gt;
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/target/surefire-reports&gt;
T E S T S
Running org.geoserver.filter.function.GeometryCollectorFunctionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.556 sec
Running org.geoserver.filter.function.QueryLayerFunctionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.035 sec
Running org.geoserver.filter.function.WFSFilteringTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.396 sec
Results :
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/target/querylayer-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/target/querylayer-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/target/querylayer-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/target/querylayer-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/target/querylayer-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/querylayer/2.3-SNAPSHOT/querylayer-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/target/querylayer-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/querylayer/2.3-SNAPSHOT/querylayer-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/target/querylayer-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/querylayer/2.3-SNAPSHOT/querylayer-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/querylayer/target/querylayer-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/querylayer/2.3-SNAPSHOT/querylayer-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Teradata DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 14.12.2012 @ 14:57:20 UTC
Conflicts:
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/src/main/resources&gt;
[INFO] snapshot org.geotools.jdbc:gt-jdbc-teradata:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-teradata:9-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/src/test/resources&gt;
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/target/teradata-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/target/teradata-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/target/teradata-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/target/teradata-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/target/teradata-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/teradata/2.3-SNAPSHOT/teradata-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/target/teradata-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/teradata/2.3-SNAPSHOT/teradata-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/target/teradata-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/teradata/2.3-SNAPSHOT/teradata-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/teradata/target/teradata-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/teradata/2.3-SNAPSHOT/teradata-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer CAS Security Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/security/cas/target&gt;
Conflicts:
[INFO] [GitCommitIdMojo] build.build.time = 14.12.2012 @ 14:57:23 UTC
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/security/cas/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;:\[11,21\] package oracle.net.ano does not exist
[INFO] Total time: 30 minutes 34 seconds
[INFO] Finished at: Fri Dec 14 14:57:25 UTC 2012
[INFO] Final Memory: 82M/243M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5693/changes&gt;
Dear Sir,
I am creating Web GIS spatial information system for airport site. I received 83 layers in *.shp format. I uploaded all shape file into postgresql server. I created web cache using tile layer option in geo server. we made URL http;//localhost:8082/geoserver/gwc/services/wms. shall i enable direct integration to gwc. My server config IBM Xeon 2.39 GHz, Ram 32 GB,1TB memory,still i am facing speed issue. Can u help me.
Thanks & Regards
Girish Kumar Pathak
Senior Software Engineer (WebGis)
Geokno India Private Limited
(A GMR Group company)
IBC Knowledge Park, Phase 2, “D” Block,
4th Floor,4/1,Bannerghatta Road,
Bangalore - 560 029
Karnataka
Mobile: +91 7406196366
Email-Id: girish@anonymised.com
www.geokno.com
On Fri, Dec 14, 2012 at 10:10 PM, Hudson <monitor@anonymised.com> wrote:
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5693/changes>
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d
Geoserver-devel mailing list
