See <http://hudson.opengeo.org/hudson/job/geoserver-master/5902/changes>
Changes:
[Davide Savazzi] GEOS5672: fixed nested group loop
[...truncated 7947 lines...]
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1355)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1374)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1309)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:921)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:904)
at org.geoserver.wms.WMSServiceExceptionTest.testPng8InImageFormat130(WMSServiceExceptionTest.java:53)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
at org.junit.rules.RunRules.evaluate(RunRules.java:18)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
04 Mar 18:42:31 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer foobar
at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1244)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:209)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:79)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1413)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
at org.geoserver.wms.WMSServiceExceptionTest.assertResponse130(WMSServiceExceptionTest.java:78)
at org.geoserver.wms.WMSServiceExceptionTest.testException130(WMSServiceExceptionTest.java:74)
at org.geoserver.wms.WMSServiceExceptionTest.testJsonException130(WMSServiceExceptionTest.java:94)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.663 sec
Running org.geoserver.wms.WMSExtensionsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.wms.ResourceAccessManagerWMSTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.137 sec
Running org.geoserver.wms.legendgraphic.AbstractLegendGraphicOutputFormatTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.704 sec
Running org.geoserver.wms.legendgraphic.GetLegendGraphicKvpReaderTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.448 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.781 sec
Running org.geoserver.wms.map.RawMapTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.168 sec
Running org.geoserver.wms.map.GIFMapResponseTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.763 sec
Running org.geoserver.wms.map.GetMapKvpRequestReaderTest
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.6 sec
Running org.geoserver.wms.map.quantize.ColorIndexerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.034 sec
Running org.geoserver.wms.map.quantize.QuantizerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.838 sec
Running org.geoserver.wms.map.quantize.ColorMapTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wms.map.RasterWithoutOutlineMapStyleTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.917 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wms.map.GetMapIntegrationTest
04 Mar 18:42:40 ERROR [image.test] - perceptualdiff is not available, can't compare src/test/resources/org/geoserver/wms/map/indexed-expected.png with image2
04 Mar 18:42:40 ERROR [image.test] - perceptualdiff is not available, can't compare src/test/resources/org/geoserver/wms/map/indexed-bg-expected.png with image2
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.584 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.548 sec
Running org.geoserver.wms.georss.AtomGeoRSSTransformerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.592 sec
Running org.geoserver.wms.georss.RSSGeoRSSTransformerTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.541 sec
Running org.geoserver.wms.GetMapOutputFormatTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.424 sec
Running org.geoserver.wms.RenderingBufferTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.601 sec
Running org.geoserver.wms.decoration.ScaleLineDecorationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.wms.decoration.MapDecorationLayoutTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.wms.decoration.ScaleRatioDecorationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.wms.WMSTest
04 Mar 18:42:44 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.167 sec
Results :
Tests in error:
testNestedSingleInCapabilities(org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest)
testNestedNamedInCapabilities(org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest)
testNestedNamedGetMap(org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest)
testNestedSharedGetMap(org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest)
testNestedSingleGetMap(org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest)
testNestedSingleInCapabilities(org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest)
testNestedNamedInCapabilities(org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest)
testNestedNamedGetMap(org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest)
testNestedSharedGetMap(org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest)
testNestedSingleGetMap(org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest)
Tests run: 515, Failures: 0, Errors: 10, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[INFO] Total time: 6 minutes 29 seconds
[INFO] Finished at: Mon Mar 04 18:42:45 UTC 2013
[INFO] Final Memory: 63M/372M
