See <http://hudson.opengeo.org/hudson/job/geoserver-master/5947/changes>
Changes:
[Andrea Aime] Moving featuretymetemplate to the kml module, as it's the only user of that class
[Andrea Aime] Adding placemark decorator for time
[...truncated 20628 lines...]
Caused by: org.geoserver.platform.ServiceException: Service WCS is disabled
at org.geoserver.ows.DisabledServiceCheck.serviceDispatched(DisabledServiceCheck.java:57)
... 56 more
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.089 sec
Running org.geoserver.wcs.kvp.BoundingBoxKvpParserTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.wcs.kvp.GetCoverageReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.663 sec
Running org.geoserver.wcs.kvp.RangeSubsetKvpParserTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Running org.geoserver.wcs.xml.DescribeCoverageXmlParserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.103 sec
Running org.geoserver.wcs.xml.GetCapabilitiesXmlParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.197 sec
Running org.geoserver.wcs.xml.GetCoverageXmlParserTest
class [Ljava.lang.Double;: [Ljava.lang.Double;@fd54ec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.401 sec
Results :
Tests run: 85, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ wcs1_1 ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:test-jar (default) @ wcs1_1 ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ wcs1_1 >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ wcs1_1 ---
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding placemark decorator for time
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 19.03.2013 @ 18:43:01 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-Mar-2013 22:53
[INFO] [GitCommitIdMojo] build.build.time = 19.03.2013 @ 23:06:19 UTC
[INFO] [GitCommitIdMojo] build.branch = 4739d7cb44ddad5a09516f1875cf4e25b6ce454e
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 4739d7c
[INFO] [GitCommitIdMojo] build.commit.id = 4739d7cb44ddad5a09516f1875cf4e25b6ce454e
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding placemark decorator for time
[INFO]
[INFO] --- javacc-maven-plugin:2.3:jjtree (jjtree) @ wcs1_1 ---
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset> are up to date.
[INFO]
[INFO] --- javacc-maven-plugin:2.3:javacc (javacc) @ wcs1_1 ---
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_1/target/generated-sources/jjtree> are up to date.
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ wcs1_1 <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ wcs1_1 ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ wcs1_1 >>>
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ wcs1_1 <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ wcs1_1 ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ wcs1_1 ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_1/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Web Map Service KML output formats 2.4-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ kml ---
[INFO] Deleting <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/kml/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ kml ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ kml ---
[INFO] [GitCommitIdMojo] build.build.time = 19.03.2013 @ 23:06:20 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ kml ---
[debug] execute contextualize
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/kml/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ kml ---
[INFO] Compiling 29 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/kml/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/kml/src/main/java/org/geoserver/kml/KMLMapTransformer.java>:\[985,36\] cannot find symbol
symbol : class FeatureTimeTemplate
location: class org.geoserver.kml.KMLMapTransformer.KMLMapTranslatorSupport
[INFO] 1 error
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.624s]
[INFO] Core Platform Module .............................. SUCCESS [4.790s]
[INFO] Open Web Service Module ........................... SUCCESS [10.270s]
[INFO] Main Module ....................................... SUCCESS [1:56.012s]
[INFO] Web Feature Service Module ........................ SUCCESS [1:47.966s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.201s]
[INFO] Web Map Service Module ............................ SUCCESS [2:00.445s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.261s]
[INFO] Core UI Module .................................... SUCCESS [59.181s]
[INFO] Security UI Module ................................ SUCCESS [2:07.430s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.405s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [2:09.522s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [3.460s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [33.077s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [36.705s]
[INFO] Web Map Service KML output formats ................ FAILURE [2.620s]
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 12:44.760s
[INFO] Finished at: Tue Mar 19 23:06:22 UTC 2013
[INFO] Final Memory: 33M/182M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project kml: Compilation failure
[ERROR] symbol : class FeatureTimeTemplate
[ERROR] location: class org.geoserver.kml.KMLMapTransformer.KMLMapTranslatorSupport
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :kml
