See <http://hudson.opengeo.org/hudson/job/geoserver-master/6292/changes>
Changes:
[Andrea Aime] [GEOS-6007] WFS bbox filters with the 5th srs parameter will loose the srsName if the CRS cannot be turned back into a code (e.g., AUTO:xyzw projections)
[David Winslow] Update GeoScript dependency in CSS extension
[...truncated 10687 lines...]
Caused by: javax.xml.transform.TransformerException: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: wcs:DEM
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:716)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:313)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:300)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:112)
at org.geoserver.wcs.response.Wcs10DescribeCoverageResponse.write(Wcs10DescribeCoverageResponse.java:35)
... 56 more
Caused by: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: wcs:DEM
at org.geoserver.wcs.response.Wcs10DescribeCoverageTransformer$WCS100DescribeCoverageTranslator.encode(Wcs10DescribeCoverageTransformer.java:187)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:1026)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(TransformerImpl.java:636)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:707)
... 61 more
29 Aug 16:50:42 ERROR [geoserver.ows] -
org.vfny.geoserver.wcs.WcsException: Version has not been specified
at org.geoserver.wcs.kvp.Wcs10DescribeCoverageKvpRequestReader.read(Wcs10DescribeCoverageKvpRequestReader.java:38)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1412)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1431)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1450)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1385)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:934)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:917)
at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:902)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1228)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1163)
at org.geoserver.wcs.DescribeCoverageTest.testDescribeMissingVersion(DescribeCoverageTest.java:79)
ERROR: 'Could not find the specified coverage: cdf:DEM'
java.io.IOException
at org.geoserver.wcs.response.Wcs10DescribeCoverageResponse.write(Wcs10DescribeCoverageResponse.java:37)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:919)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1367)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1131)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1066)
at org.geoserver.test.GeoServerSystemTestSupport.post(GeoServerSystemTestSupport.java:1046)
at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1316)
at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1299)
at org.geoserver.wcs.DescribeCoverageTest.testWorkspaceQualified(DescribeCoverageTest.java:292)
Caused by: javax.xml.transform.TransformerException: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: cdf:DEM
... 56 more
Caused by: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: cdf:DEM
... 61 more
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.060s]
[INFO] Core Platform Module .............................. SUCCESS [5.594s]
[INFO] Open Web Service Module ........................... SUCCESS [13.654s]
[INFO] Main Module ....................................... SUCCESS [2:23.135s]
[INFO] Web Feature Service Module ........................ FAILURE [3:11.961s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.874s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.665s]
[INFO] Core UI Module .................................... SUCCESS [1:45.330s]
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] REST Support Module ............................... SUCCESS [28.125s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.253s]
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.197s]
[INFO] Application Schema Support ........................ SUCCESS [0.234s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.462s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.336s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.610s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.552s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.625s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.729s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SUCCESS [3.816s]
[INFO] Chart external graphics support ................... SUCCESS [1.967s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.622s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.986s]
[INFO] OWS request flow controller ....................... SUCCESS [20.671s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.192s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.468s]
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 6:20.824s (Wall Clock)
[INFO] Finished at: Thu Aug 29 16:50:42 UTC 2013
[INFO] Final Memory: 36M/288M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :wfs
