See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3614/>
[...truncated 28904 lines...]
[INFO] Copying 0 resource
[INFO] Copying 18 resources
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.ows/10-SNAPSHOT/net.opengis.ows-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-core/10-SNAPSHOT/gt-xsd-core-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-metadata/10-SNAPSHOT/gt-metadata-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wfs/10-SNAPSHOT/net.opengis.wfs-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml2/10-SNAPSHOT/gt-xsd-gml2-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.fes/10-SNAPSHOT/net.opengis.fes-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-main/10-SNAPSHOT/gt-main-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-coverage/10-SNAPSHOT/gt-coverage-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-validation/10-SNAPSHOT/gt-validation-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/10-SNAPSHOT/gt-xsd-sld-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-data/10-SNAPSHOT/gt-data-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/10-SNAPSHOT/gt-jdbc-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-epsg-hsql/10-SNAPSHOT/gt-epsg-hsql-10-SNAPSHOT.jar
[INFO] Nothing to compile - all classes are up to date
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/css/src/test/resources>
[INFO] Tests are skipped.
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/css/target/css-2.4-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/css/target/css-2.4-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/css/target/css-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/css/2.4-SNAPSHOT/css-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/css/target/css-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/css/2.4-SNAPSHOT/css-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/css/target/css-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/css/2.4-SNAPSHOT/css-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/css/target/css-2.4-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/css/2.4-SNAPSHOT/css-2.4-SNAPSHOT-test-sources.jar
[INFO] [deploy:deploy {execution: default-deploy}]
[INFO] Retrieving previous build number from opengeo
Uploading: http://repo.opengeo.org/org/geoserver/extension/css/2.4-SNAPSHOT/css-2.4-SNAPSHOT.jar
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32768/?
36864/?
40960/?
45056/?
49152/?
53248/?
57344/?
61440/?
65536/?
68489/?
[INFO] Uploading project information for css 2.4-SNAPSHOT
[INFO] Retrieving previous metadata from opengeo
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:css:2.4-SNAPSHOT'
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:css'
Uploading: http://repo.opengeo.org/org/geoserver/extension/css/2.4-SNAPSHOT/css-2.4-SNAPSHOT-tests.jar
3931/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/css/2.4-SNAPSHOT/css-2.4-SNAPSHOT-sources.jar
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
25510/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/css/2.4-SNAPSHOT/css-2.4-SNAPSHOT-test-sources.jar
1574/?
[INFO]
[INFO]
[INFO] Reactor Summary:
[INFO] GeoServer ............................................. SUCCESS [25.177s]
[INFO] Core Platform Module .................................. SUCCESS [4.489s]
[INFO] Open Web Service Module ............................... SUCCESS [9.761s]
[INFO] Main Module ........................................... SUCCESS [34.284s]
[INFO] Web Feature Service Module ............................ SUCCESS [6.453s]
[INFO] Web Coverage Service Module ........................... SUCCESS [1.017s]
[INFO] Web Map Service Module ................................ SUCCESS [14.480s]
[INFO] GeoServer Web Modules ................................. SUCCESS [0.439s]
[INFO] Core UI Module ........................................ SUCCESS [12.543s]
[INFO] Security UI Module .................................... SUCCESS [4.345s]
[INFO] GeoServer Security Modules ............................ SUCCESS [0.546s]
[INFO] GeoServer JDBC Security Module ........................ SUCCESS [3.142s]
[INFO] GeoServer LDAP Security Module ........................ SUCCESS [1.905s]
[INFO] Web Coverage Service 1.0 Module ....................... SUCCESS [8.384s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [3.086s]
[INFO] KML support for GeoServer ............................. SUCCESS [2.674s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [9.470s]
[INFO] REST Support Module ................................... SUCCESS [1.003s]
[INFO] REST Configuration Service Module ..................... SUCCESS [5.462s]
[INFO] WMS UI Module ......................................... SUCCESS [2.107s]
[INFO] GWC UI Module ......................................... SUCCESS [2.250s]
[INFO] WFS UI Module ......................................... SUCCESS [1.079s]
[INFO] Demoes Module ......................................... SUCCESS [3.615s]
[INFO] WCS UI Module ......................................... SUCCESS [1.273s]
[INFO] Community Space ....................................... SUCCESS [0.575s]
[INFO] Printing Module ....................................... SUCCESS [10.771s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [2.842s]
[INFO] GeoServer Embedded FTP server ......................... SUCCESS [2.312s]
[INFO] GeoServer Web Application ............................. SUCCESS [16.772s]
[INFO] GeoServer Extensions .................................. SUCCESS [0.948s]
[INFO] Application Schema Support ............................ SUCCESS [5.670s]
[INFO] Application Schema Integration Test ................... SUCCESS [12.070s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [2.784s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [2.415s]
[INFO] GeoSearch Index Module ................................ SUCCESS [2.187s]
[INFO] H2 DataStore Extension ................................ SUCCESS [1.013s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [1.010s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [0.889s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [2.491s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [1.002s]
[INFO] ImageMap Output Format ................................ SUCCESS [1.963s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .................. SUCCESS [2.601s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [0.999s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [1.044s]
[INFO] Excel Output Format ................................... SUCCESS [2.106s]
[INFO] Validation Module ..................................... SUCCESS [1.059s]
[INFO] Chart external graphics support ....................... SUCCESS [1.810s]
[INFO] Feature Generalization Extension ...................... SUCCESS [2.321s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [1.055s]
[INFO] OWS request flow controller ........................... SUCCESS [1.237s]
[INFO] Web Processing Service parent ......................... SUCCESS [0.477s]
[INFO] Web Processing Service Module ......................... SUCCESS [23.392s]
[INFO] Web Processing Service GUI ............................ SUCCESS [2.221s]
[INFO] GeoServer Layer Querying filter functions ............. SUCCESS [1.310s]
[INFO] Teradata DataStore Extension .......................... SUCCESS [3.463s]
[INFO] GeoServer Monitor Extensions .......................... SUCCESS [0.582s]
[INFO] Core Monitor Extension ................................ SUCCESS [5.055s]
[INFO] Monitor Hibernate Extension ........................... SUCCESS [2.605s]
[INFO] GeoServer CAS Security Module ......................... SUCCESS [1.614s]
[INFO] GeoServer Security Extension Modules .................. SUCCESS [0.662s]
[INFO] XLST based WFS output format .......................... SUCCESS [2.408s]
[INFO] GeoServer INSPIRE Extensions .......................... SUCCESS [3.169s]
[INFO] GeoServer CSS Styling ................................. SUCCESS [5.949s]
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 5 minutes 6 seconds
[INFO] Finished at: Mon Aug 05 14:41:39 UTC 2013
[INFO] Final Memory: 88M/363M
[src] $ /bin/sh -xe /var/cache/jetty/data/hudson6880181428024446410.sh
+ VER=2.4-SNAPSHOT
+ cd web/app/target
+ md5sum web-app-2.4-SNAPSHOT.jar
+ sha1sum web-app-2.4-SNAPSHOT.jar
+ curl -u hudson:chrono44logic -T web-app-2.4-SNAPSHOT.jar http://repo.opengeo.org/org/geoserver/web/web-app/2.4-SNAPSHOT/web-app-2.4-SNAPSHOT.jar
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 4476 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
101 4476 0 0 101 4476 0 18826 --:--:-- --:--:-- --:--:-- 485k
+ curl -u hudson:chrono44logic -T web-app-2.4-SNAPSHOT.jar.md5 http://repo.opengeo.org/org/geoserver/web/web-app/2.4-SNAPSHOT/web-app-2.4-SNAPSHOT.jar.md5
0 59 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
0 59 0 0 0 59 0 119 --:--:-- --:--:-- --:--:-- 361
+ curl -u hudson:chrono44logic -T web-app-2.4-SNAPSHOT.jar.sha1 http://repo.opengeo.org/org/geoserver/web/web-app/2.4-SNAPSHOT/web-app-2.4-SNAPSHOT.jar.sha1
0 67 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
0 67 0 0 0 67 0 211 --:--:-- --:--:-- --:--:-- 4466
Looks like the node went offline during the build. Check the slave log for the details.FATAL: /var/lib/hudson/slave-null.log (No such file or directory)
java.io.FileNotFoundException: /var/lib/hudson/slave-null.log (No such file or directory)
at java.io.RandomAccessFile.open(Native Method)
at java.io.RandomAccessFile.<init>(RandomAccessFile.java:212)
at org.kohsuke.stapler.framework.io.LargeText$FileSession.<init>(LargeText.java:349)
at org.kohsuke.stapler.framework.io.LargeText$1.open(LargeText.java:75)
at org.kohsuke.stapler.framework.io.LargeText.writeLogTo(LargeText.java:164)
at hudson.console.AnnotatedLargeText.writeHtmlTo(AnnotatedLargeText.java:154)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:441)
at hudson.model.Run.run(Run.java:1366)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:145)
