[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-nightly #1267
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1267/&gt;
[...truncated 4480 lines...]
4308/4977K
4312/4977K
4316/4977K
4320/4977K
4324/4977K
4328/4977K
4332/4977K
4336/4977K
4340/4977K
4344/4977K
4348/4977K
4352/4977K
4356/4977K
4360/4977K
4364/4977K
4368/4977K
4372/4977K
4376/4977K
4380/4977K
4384/4977K
4388/4977K
4392/4977K
4396/4977K
4400/4977K
4404/4977K
4408/4977K
4412/4977K
4416/4977K
4420/4977K
4424/4977K
4428/4977K
4432/4977K
4436/4977K
4440/4977K
4444/4977K
4448/4977K
4452/4977K
4456/4977K
4460/4977K
4464/4977K
4468/4977K
4472/4977K
4476/4977K
4480/4977K
4484/4977K
4488/4977K
4492/4977K
4496/4977K
4500/4977K
4504/4977K
4508/4977K
4512/4977K
4516/4977K
4520/4977K
4524/4977K
4528/4977K
4532/4977K
4536/4977K
4540/4977K
4544/4977K
4548/4977K
4552/4977K
4556/4977K
4560/4977K
4564/4977K
4568/4977K
4572/4977K
4576/4977K
4580/4977K
4584/4977K
4588/4977K
4592/4977K
4596/4977K
4600/4977K
4604/4977K
4608/4977K
4612/4977K
4616/4977K
4620/4977K
4624/4977K
4628/4977K
4632/4977K
4636/4977K
4640/4977K
4644/4977K
4648/4977K
4652/4977K
4656/4977K
4660/4977K
4664/4977K
4668/4977K
4672/4977K
4676/4977K
4680/4977K
4684/4977K
4688/4977K
4692/4977K
4696/4977K
4700/4977K
4704/4977K
4708/4977K
4712/4977K
4716/4977K
4720/4977K
4724/4977K
4728/4977K
4732/4977K
4736/4977K
4740/4977K
4744/4977K
4748/4977K
4752/4977K
4756/4977K
4760/4977K
4764/4977K
4768/4977K
4772/4977K
4776/4977K
4780/4977K
4784/4977K
4788/4977K
4792/4977K
4796/4977K
4800/4977K
4804/4977K
4808/4977K
4812/4977K
4816/4977K
4820/4977K
4824/4977K
4828/4977K
4832/4977K
4836/4977K
4840/4977K
4844/4977K
4848/4977K
4852/4977K
4856/4977K
4860/4977K
4864/4977K
4868/4977K
4872/4977K
4876/4977K
4880/4977K
4884/4977K
4888/4977K
4892/4977K
4896/4977K
4900/4977K
4904/4977K
4908/4977K
4912/4977K
4916/4977K
4920/4977K
4924/4977K
4928/4977K
4932/4977K
4936/4977K
4940/4977K
4944/4977K
4948/4977K
4952/4977K
4956/4977K
4960/4977K
4964/4977K
4968/4977K
4972/4977K
4976/4977K
4977/4977K
4977K downloaded (groovy-1.7.10.jar)
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/classes&gt;
[INFO] Copying 5 resources
[INFO] Compiling 4 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/dependency/gwc-core-1.3-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-groovy/2.3-SNAPSHOT/script-groovy-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-groovy/2.3-SNAPSHOT/script-groovy-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-groovy/2.3-SNAPSHOT/script-groovy-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-groovy/2.3-SNAPSHOT/script-groovy-2.3-SNAPSHOT-test-sources.jar
[INFO] Building JavaScript Scripting Extension
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugins/maven-shade-plugin/1.6/maven-shade-plugin-1.6.pom
[WARNING] Unable to get resource 'org.apache.maven.plugins:maven-shade-plugin:pom:1.6' from repository central (http://repo1.maven.org/maven2): Error transferring file: repo1.maven.org
Downloading: http://repo.opengeo.org//org/apache/maven/plugins/maven-shade-plugin/1.6/maven-shade-plugin-1.6.pom
[INFO] Unable to find resource 'org.apache.maven.plugins:maven-shade-plugin:pom:1.6' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/apache/maven/plugins/maven-shade-plugin/1.6/maven-shade-plugin-1.6.pom
[INFO] Unable to find resource 'org.apache.maven.plugins:maven-shade-plugin:pom:1.6' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://maven.restlet.org/org/apache/maven/plugins/maven-shade-plugin/1.6/maven-shade-plugin-1.6.pom
[INFO] Unable to find resource 'org.apache.maven.plugins:maven-shade-plugin:pom:1.6' in repository maven-restlet (http://maven.restlet.org)
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.apache.maven.plugins:maven-shade-plugin
Reason: POM 'org.apache.maven.plugins:maven-shade-plugin' not found in repository: Unable to download the artifact from any repository
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
  codehaus-snapshot-plugins (http://snapshots.repository.codehaus.org/),
for project org.apache.maven.plugins:maven-shade-plugin
[INFO] Total time: 4 minutes 3 seconds
[INFO] Finished at: Thu Nov 01 15:05:11 UTC 2012
[INFO] Final Memory: 103M/414M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-11-01-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1268/&gt;
