See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/1265/>
[...truncated 35080 lines...]
sleep interrupted
Thread[Thread-13,5,main] calling requestComplete
Thread[Thread-13,5,main] done
sleep interrupted
Thread[Thread-14,5,main] calling requestComplete
Thread[Thread-14,5,main] done
Thread[Thread-15,5,main] calling requestIncoming
Thread[Thread-15,5,main] waiting
Thread[Thread-15,5,main] calling requestComplete
Thread[Thread-15,5,main] done
Thread[Thread-16,5,main] calling requestIncoming
Thread[Thread-16,5,main] waiting
Thread[Thread-17,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-16,5,main] calling requestComplete
Thread[Thread-16,5,main] done
Thread[Thread-17,5,main] waiting
sleep interrupted
Thread[Thread-17,5,main] calling requestComplete
Thread[Thread-17,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.227 sec
Running org.geoserver.flow.controller.SingleIpFlowControllerTest
Thread[Thread-18,5,main] calling requestIncoming
Thread[Thread-18,5,main] waiting
Thread[Thread-18,5,main] calling requestComplete
Thread[Thread-18,5,main] done
Thread[Thread-19,5,main] calling requestIncoming
Thread[Thread-19,5,main] waiting
Thread[Thread-20,5,main] calling requestIncoming
Thread[Thread-20,5,main] waiting
sleep interrupted
Thread[Thread-19,5,main] calling requestComplete
Thread[Thread-19,5,main] done
sleep interrupted
Thread[Thread-20,5,main] calling requestComplete
Thread[Thread-20,5,main] done
Thread[Thread-21,5,main] calling requestIncoming
Thread[Thread-21,5,main] waiting
Thread[Thread-21,5,main] calling requestComplete
Thread[Thread-21,5,main] done
Thread[Thread-22,5,main] calling requestIncoming
Thread[Thread-22,5,main] waiting
Thread[Thread-23,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-22,5,main] calling requestComplete
Thread[Thread-22,5,main] done
Thread[Thread-23,5,main] waiting
sleep interrupted
Thread[Thread-23,5,main] calling requestComplete
Thread[Thread-23,5,main] done
Thread[Thread-24,5,main] calling requestIncoming
Thread[Thread-24,5,main] waiting
Thread[Thread-24,5,main] calling requestComplete
Thread[Thread-24,5,main] done
Thread[Thread-25,5,main] calling requestIncoming
Thread[Thread-25,5,main] waiting
Thread[Thread-26,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-25,5,main] calling requestComplete
Thread[Thread-25,5,main] done
Thread[Thread-26,5,main] waiting
sleep interrupted
Thread[Thread-26,5,main] calling requestComplete
Thread[Thread-26,5,main] done
Thread[Thread-27,5,main] calling requestIncoming
Thread[Thread-27,5,main] waiting
Thread[Thread-28,5,main] calling requestIncoming
Thread[Thread-28,5,main] waiting
sleep interrupted
Thread[Thread-27,5,main] calling requestComplete
Thread[Thread-27,5,main] done
sleep interrupted
Thread[Thread-28,5,main] calling requestComplete
Thread[Thread-28,5,main] done
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.31 sec
Results :
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/gt-referencing/10-SNAPSHOT/gt-referencing-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-metadata/10-SNAPSHOT/gt-metadata-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-opengis/10-SNAPSHOT/gt-opengis-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-epsg-hsql/10-SNAPSHOT/gt-epsg-hsql-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-render/10-SNAPSHOT/gt-render-10-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.4-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.4-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.4-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.4-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/control-flow/target/control-flow-2.4-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service parent
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/target>
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5891] REST config upload fail in path with spaces
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 17.07.2013 @ 17:15:09 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 18-Jul-2013 04:09
[INFO] [GitCommitIdMojo] build.build.time = 18.07.2013 @ 04:35:24 UTC
[INFO] [GitCommitIdMojo] build.branch = 3c1af14445bcef284198f6c8b964a3233bfd2c20
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3c1af14
[INFO] [GitCommitIdMojo] build.commit.id = 3c1af14445bcef284198f6c8b964a3233bfd2c20
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5891] REST config upload fail in path with spaces
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
Downloading: http://repo.opengeo.org//org/geotools/gt-api/10-SNAPSHOT/gt-api-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-main/10-SNAPSHOT/gt-main-10-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/target/wps-2.4-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps/2.4-SNAPSHOT/wps-2.4-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/target/wps-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps/2.4-SNAPSHOT/wps-2.4-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/wps-core/target>
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO] snapshot org.geotools.ogc:net.opengis.wps:10-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.ogc:net.opengis.wps:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:10-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process-geometry:10-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process-geometry:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process-geometry:10-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.fes/10-SNAPSHOT/net.opengis.fes-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-arcgrid/10-SNAPSHOT/gt-arcgrid-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-wcs/10-SNAPSHOT/gt-xsd-wcs-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wcs/10-SNAPSHOT/net.opengis.wcs-10-SNAPSHOT.jar
[INFO] Compiling 121 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/wps-core/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/wps-core/src/main/java/org/geoserver/wps/raster/CoverageUtilities.java>:\[173,34\] cannot find symbol
symbol : constructor RangeLookupTable(java.lang.Number)
location: class org.jaitools.media.jai.rangelookup.RangeLookupTable
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/wps-core/src/main/java/org/geoserver/wps/raster/CoverageUtilities.java>:\[178,12\] cannot find symbol
symbol : method add(org.jaitools.numeric.Range,java.lang.Number)
[INFO] 2 errors
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 26 minutes 3 seconds
[INFO] Finished at: Thu Jul 18 04:35:30 UTC 2013
[INFO] Final Memory: 87M/365M
