See <http://hudson.opengeo.org/hudson/job/geoserver-master-online/991/>
[...truncated 29537 lines...]
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
Running org.geoserver.wps.gs.ContourProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.899 sec
Running org.geoserver.wps.gs.VectorZonalStatsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.401 sec
Running org.geoserver.wps.gs.ImportProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.997 sec
Running org.geoserver.wps.ExecuteTest
POLYGON ((0 1, 0 2, 0.0192147195967696 2.1950903220161284, 0.0761204674887133 2.38268343236509, 0.1685303876974546 2.555570233019602, 0.2928932188134525 2.7071067811865475, 0.444429766980398 2.8314696123025453, 0.6173165676349103 2.923879532511287, 0.8049096779838718 2.9807852804032304, 1 3, 2 3, 2.1950903220161284 2.9807852804032304, 2.3826834323650896 2.923879532511287, 2.555570233019602 2.8314696123025453, 2.7071067811865475 2.7071067811865475, 2.8314696123025453 2.555570233019602, 2.923879532511287 2.3826834323650896, 2.9807852804032304 2.1950903220161284, 3 2, 3 1, 2.9807852804032304 0.8049096779838718, 2.923879532511287 0.6173165676349102, 2.8314696123025453 0.4444297669803978, 2.7071067811865475 0.2928932188134525, 2.555570233019602 0.1685303876974548, 2.3826834323650896 0.0761204674887133, 2.1950903220161284 0.0192147195967696, 2 0, 1 0, 0.8049096779838718 0.0192147195967696, 0.6173165676349103 0.0761204674887133, 0.444429766980398 0.1685303876974546, 0.2928932188134525 0.2928932188134524, 0.1685303876974546 0.4444297669803978, 0.0761204674887133 0.6173165676349102, 0.0192147195967696 0.8049096779838714, 0 1))
15 Oct 04:29:39 ERROR [geoserver.wps] - Process execution failed
org.geotools.process.ProcessException: Sorry dude, things went pear shaped...
at org.geoserver.wps.ExecuteTest.testProcessFailure(ExecuteTest.java:814)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.rules.RunRules.evaluate(RunRules.java:18)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
15 Oct 04:29:40 ERROR [wps.executor] - Request failed during output encoding
java.io.IOException
at org.geoserver.ows.XmlObjectEncodingResponse.write(XmlObjectEncodingResponse.java:55)
at org.geoserver.wps.executor.WPSExecutionManager$AsynchronousProcessContext.writeOutResponse(WPSExecutionManager.java:368)
at org.geoserver.wps.executor.WPSExecutionManager$AsynchronousProcessContext.writeResponseFile(WPSExecutionManager.java:339)
at org.geoserver.wps.executor.WPSExecutionManager$1.run(WPSExecutionManager.java:113)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.RuntimeException: java.lang.RuntimeException: Toasted!
at org.geotools.xml.Encoder.encode(Encoder.java:711)
at org.geotools.xml.Encoder.encode(Encoder.java:584)
at org.geoserver.ows.XmlObjectEncodingResponse.write(XmlObjectEncodingResponse.java:52)
... 9 more
Caused by: java.lang.RuntimeException: Toasted!
at org.geoserver.wps.ExecuteTest$1.openIterator(ExecuteTest.java:1030)
at org.geotools.feature.collection.AbstractFeatureCollection.iterator(AbstractFeatureCollection.java:343)
at org.geotools.xml.Encoder.encode(Encoder.java:1025)
at org.geoserver.wps.ppio.WFSPPIO.encode(WFSPPIO.java:191)
at org.geoserver.wps.XMLEncoderDelegate.encode(XMLEncoderDelegate.java:30)
at org.geotools.xml.Encoder.encode(Encoder.java:708)
... 11 more
Tests run: 29, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.923 sec
Running org.geoserver.wps.SnapTest
15 Oct 04:29:42 ERROR [geoserver.wps] - Process execution failed
org.geotools.process.ProcessException: Parameter features is missing but has min multiplicity > 0
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.buildProcessArguments(AnnotationDrivenProcessFactory.java:633)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:501)
at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:215)
at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:189)
org.geotools.process.ProcessException: Parameter point is missing but has min multiplicity > 0
org.geotools.process.ProcessException: Process execution 6bc10cdc-0a7d-4950-bd26-0f42d8327ebc failed
at org.geoserver.wps.executor.DefaultProcessManager.getOutput(DefaultProcessManager.java:157)
at org.geoserver.wps.executor.WPSExecutionManager.getOutput(WPSExecutionManager.java:173)
at org.geoserver.wps.Execute.run(Execute.java:75)
at org.geoserver.wps.DefaultWebProcessingService.execute(DefaultWebProcessingService.java:76)
at sun.reflect.GeneratedMethodAccessor182.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy25.execute(Unknown Source)
at sun.reflect.GeneratedMethodAccessor181.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1336)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1355)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1290)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1272)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1099)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1046)
at org.geoserver.test.GeoServerSystemTestSupport.post(GeoServerSystemTestSupport.java:1026)
at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1233)
at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1216)
at org.geoserver.wps.SnapTest.testWrongCRS(SnapTest.java:445)
Caused by: org.geoserver.wps.WPSException: Failed to retrieve value for input crs
at org.geoserver.wps.executor.LazyInputMap.get(LazyInputMap.java:37)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.buildProcessArguments(AnnotationDrivenProcessFactory.java:616)
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:EPSG" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:951)
at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:316)
at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:390)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:783)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:801)
at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:640)
at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:489)
at org.geotools.referencing.CRS.decode(CRS.java:417)
at org.geoserver.wps.ppio.CoordinateReferenceSystemPPIO.decode(CoordinateReferenceSystemPPIO.java:29)
at org.geoserver.wps.executor.SimpleInputProvider.getValue(SimpleInputProvider.java:132)
at org.geoserver.wps.executor.LazyInputMap.get(LazyInputMap.java:35)
... 9 more
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.903 sec
Results :
Failed tests: testIncompatibleGridCoverages(org.geoserver.wps.gs.BinaryProcessingsTest)
testStyle(org.geoserver.wps.gs.StyleCoverageTest): expected:<[attachment; filename=result.tiff]> but was:<[inline; filename=execute.xml]>
testStore(org.geoserver.wps.gs.StoreCoverageTest)
testStatisticsTazDem(org.geoserver.wps.gs.RasterZonalStatsTest): expected:<[14400]> but was:<>
testStatisticsSfDem(org.geoserver.wps.gs.RasterZonalStatsTest): expected:<[424]> but was:<>
Tests in error:
testStatisticsTazDem(org.geoserver.wps.gs.RasterAsPointCollectionTest): java.util.HashMap cannot be cast to net.opengis.wfs.FeatureCollectionType
testAddOperation(org.geoserver.wps.gs.BinaryProcessingsTest): Unable to parse the header for the provided input
testMultiplyOperation(org.geoserver.wps.gs.BinaryProcessingsTest): Unable to parse the header for the provided input
testScale(org.geoserver.wps.gs.ScaleCoverageTest): Unable to parse the header for the provided input
testCrop(org.geoserver.wps.gs.CropCoverageTest): Unable to parse the header for the provided input
testRangeLookup(org.geoserver.wps.gs.RangeLookupTest): Unable to parse the header for the provided input
Tests run: 128, Failures: 5, Errors: 6, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master-online/ws/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[INFO] Total time: 21 minutes 11 seconds
[INFO] Finished at: Mon Oct 15 04:29:42 UTC 2012
[INFO] Final Memory: 81M/362M
