See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/5020/changes>
Changes:
[NielsCharlier] GEOS-5032 GetLegendGraphic doesn't work for WMS with app-schema
[...truncated 23739 lines...]
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: org.geoserver.wfs.WFSTransactionException: Update error: Transaction does not have authorization for Locks:Locks.0
at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:260)
at org.geoserver.wfs.Transaction.execute(Transaction.java:319)
... 63 more
Caused by: org.geotools.data.FeatureLockException: Transaction does not have authorization for Locks:Locks.0
at org.geotools.data.InProcessLockingManager.assertAccess(InProcessLockingManager.java:287)
at org.geotools.data.InProcessLockingManager$1.write(InProcessLockingManager.java:334)
at org.geotools.data.FilteringFeatureWriter.write(FilteringFeatureWriter.java:108)
at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:203)
at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:129)
at org.vfny.geoserver.global.GeoServerFeatureStore.modifyFeatures(GeoServerFeatureStore.java:182)
at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:254)
... 64 more
05 Apr 14:45:16 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock7790212885715581758data>
05 Apr 14:45:17 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock707817750018204594data>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.43 sec
Running org.geoserver.wfs.ReprojectionWriteTest
05 Apr 14:45:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock5600061742478347940data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock3321983740022638719data>
05 Apr 14:45:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock1118404639671021257data>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.702 sec
Running org.geoserver.wfs.AliasTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock2599930730279265173data>
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<xsd:schema xmlns:cdf="http://www.opengis.net/cite/data" xmlns:gml="http://www.opengis.net/gml" xmlns:gs="http://geoserver.org" xmlns:xsd="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" targetNamespace="http://www.opengis.net/cite/data">
<xsd:import namespace="http://www.opengis.net/gml" schemaLocation="http://localhost:8080/geoserver/schemas/gml/2.1.2/feature.xsd"/>
<xsd:complexType name="ft15Type">
<xsd:complexContent>
<xsd:extension base="gml:AbstractFeatureType">
<xsd:sequence>
<xsd:element maxOccurs="1" minOccurs="0" name="boundedBy" nillable="true" type="gml:PolygonPropertyType"/>
<xsd:element maxOccurs="1" minOccurs="0" name="pointProperty" nillable="true" type="gml:PointPropertyType"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name="ft15" substitutionGroup="gml:_Feature" type="cdf:ft15Type"/>
</xsd:schema>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.396 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
05 Apr 14:45:20 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/./target/mock8612609906980319096data>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.625 sec
Results :
Tests run: 406, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.ows/8-SNAPSHOT/net.opengis.ows-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-ows/8-SNAPSHOT/gt-xsd-ows-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-data/8-SNAPSHOT/gt-data-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml2/8-SNAPSHOT/gt-xsd-gml2-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs> (directory)
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs> (directory)
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/src/main/resources>
Downloading: http://repo.opengeo.org//org/geotools/gt-gtopo30/8-SNAPSHOT/gt-gtopo30-8-SNAPSHOT.jar
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/classes>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/src/test/resources>
[INFO] Nothing to compile - all classes are up to date
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/surefire-reports>
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-2.2-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-2.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs/2.2-SNAPSHOT/wcs-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-2.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs/2.2-SNAPSHOT/wcs-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-2.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs/2.2-SNAPSHOT/wcs-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-2.2-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wcs/2.2-SNAPSHOT/wcs-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms> (directory)
[INFO] Copying 1 resource
[INFO] Copying 64 resources
[INFO] snapshot org.geotools:gt-svg:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-svg:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 175 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/src/main/java/org/geoserver/wms/legendgraphic/BufferedImageLegendGraphicBuilder.java>:\[536,42\] cannot find symbol
symbol : method templateFeature(org.opengis.feature.type.FeatureType)
[INFO] Total time: 8 minutes 36 seconds
[INFO] Finished at: Thu Apr 05 14:45:32 UTC 2012
[INFO] Final Memory: 55M/389M
Failed to send e-mail to NielsCharlier because no e-mail address is known, and no default e-mail domain is configured
