[Geoserver-devel] imagemosaic having some gaps on differnt zoom levels
I'm using the imagemosaicer to mosaic tiles together with different crs. In
this example I'm combining EPSG:32631 and EPSG:32630. Al the tiles are
having pyramides. On some zoom levels, it is having a gap like some tiles
are completely skipped. I have no clue why. Is this a known issue?
2 screenshot are attached. The same area, on 2 different zoomlevels.
<http://osgeo-org.1560.x6.nabble.com/file/t195737/uk_without_gap.png&gt;
<http://osgeo-org.1560.x6.nabble.com/file/t195737/uk_with_gap.png&gt;
Indexer.propertie content:
GranuleAcceptors=org.geotools.gce.imagemosaic.acceptors.HeterogeneousCRSAcceptorFactory
GranuleHandler=org.geotools.gce.imagemosaic.granulehandler.ReprojectingGranuleHandlerFactory
HeterogeneousCRS=true
TimeAttribute=ingestion
Schema=*the_geom:Polygon,location:String,ingestion:java.util.Date,crs:String
PropertyCollectors=TimestampFileNameExtractorSPI[timeregex](ingestion),CRSExtractorSPI(crs)
IndexingDirectories=/data/D/postproc/output/S2/V100/RGB/
Recursive=true
AbsolutePath=true
Name=D_RGB_V100
MosaicCRS=EPSG:4326
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-Dev-f3819232.html
I'm using geoserver 2.15.2
Hi Bart,
is any log available reporting something when these gaps occur?
Do you have a gdalinfo output of the data involved in that missing piece?
Daniele
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Daniele,
I did the same test with files without overviews but the problem remains the same.
Attached you can find the log of requests for 1 zoomlevel. When zooming further in, the images are rendered well. The logfile is from the test without overviews where the gap is visible.
Also gdalinfo of all the files is attached.
Bart Ooms
(attachments)
mosaic6.log (380 KB)
gdalinfo2.log (17.7 KB)
Hi Bart,
Daniele
On Thu, Aug 29, 2019 at 9:40 AM BartO <bart.ooms@…1770…> wrote:
I’m using geoserver 2.15.2
Geoserver-devel mailing list
Daniele Romagnoli
