[Geoserver-devel] Improving how importer deals with raster data
Does your work make it possible to implement also something like GDAL-powered WPS if the result of the import process is pushed to some place from where the user can fetch it? I can’t say any exact use case for such processing service, though, but maybe everybody do not have GDAL on their computers.
-Jukka Rahkonen-
Andrea Aime wrote:
pull request adding gdaladdo/gdalwarp/gdaltranslate here:
https://github.com/geoserver/geoserver/pull/1028
I did not get feedback on the copy thing, since it’s been out a week,
I’m assuming that at least the proposed idea is not outrageusly wrong,
so I’m going to implement it as proposed (a copy:true attribute in the
source data when we want GeoServer to copy the data locally by
itself instead of having to upload it or ingest it directly from the
source position).
On Fri, Apr 24, 2015 at 4:34 PM, Andrea Aime <andrea.aime@…1268…> wrote:
On Fri, Apr 24, 2015 at 4:07 PM, Andrea Aime <andrea.aime@…1268…> wrote:
following up on this topic, I’ve implemented the support for gdal_translate and gdaladdo in
the importer, generalizing a bit the tranfsormation chains, and providing support for other
command line invocations, should we want to add more in the future.
Oh, forgot one thing, currently the code assumes gdal_translate/gdaladdo are in the path.
Fair assumption for Linux, may not be so for Windows.
I was thinking of where to configure the location of the commands, importer currently
has no configuration at all.
Shall we go for the usual property file? $DATA_DIR/importer/gdal.properties?
I was also thinking of a $DATA_DIR/importer.xml, based of a ImporterInfo bean,
which could have a section inside.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Apr 29, 2015 at 4:11 PM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
their computers.
No, there is no relationship with WPS, although having a way to cross
importer transformations and processes would be a nice to have in the long
run.
Ing. Andrea Aime
@geowolf
Technical Lead
