[Geoserver-devel] INSPIRE extension and workspace-specific service end points
I’m testing the Geoserver with the INSPIRE extension version 2.8-SNAPSHOT. When enabling the INSPIRE metadata in WFS settings, I’m able to see INSPIRE extended capabilities in the GetCapabilties response when requesting it at the main (not workspace-specific) level. However, if I do the same GetCapabilities request at an individual workspace level, the extended capabilities is not visible. I could not find any option in the UI workspace config for enabling the INSPIRE extension.
Is this functionality by design or a bug? And if it’s by design, can I enable the INSPIRE capabilities also at the workspace level somehow?
Ilkka Rinne
Founder, Chief Technology Officer, Spatineo Oy
Email: ilkka.rinne@anonymised.com
Skype: ilkka.o.rinne, phone: +358 50 523 8974
Linnankoskenkatu 16 A 17, FI-00250 Helsinki, Finland
www.spatineo.com, twitter.com/#!/spatineo
Google+ google.com/+Spatineo
www.linkedin.com/company/spatineo-inc
-----Original Message-----
Sent: 29 October 2015 12:17
To: Geoserver-devel <geoserver-devel@lists.sourceforge.net>
Subject: [Geoserver-devel] INSPIRE extension and workspace-specific
service end points
I'm testing the Geoserver with the INSPIRE extension version 2.8-SNAPSHOT.
When enabling the INSPIRE metadata in WFS settings, I'm able to see
I have just double checked this with release v2.8.0 .
If I enable the INSPIRE extended capabilities I get the response both at the global level and doing a workspace specific request.
E.g. both
http://localhost:8080/geoserver/ows?service=wfs&acceptversions=2.0.0&request=GetCapabilities
and
http://localhost:8080/geoserver/topp/ows?service=wfs&acceptversions=2.0.0&request=GetCapabilities
give me the extended capabilities.
If I go to a page for a particular workspace (e.g. Workspaces -> topp using default sample data supplied with GeoServer) and tick the Services -> WFS check box to enable local workspace specific WFS settings I can then go to the Services -> WFS page and select the topp Workspace from the dropdown list at the top of the page to set workspace specific settings. By default, to start with, it has the same settings as the global space but I can change the INSPIRE settings or switch it off altogether and get a different response from the topp specific end-point.
Is this functionality by design or a bug? And if it's by design, can I enable the
It works the way I expect it to. Perhaps it isn't so obvious that you need to enable local settings for your service on the Workspaces page and then choose the workspace you want to set specific settings for in the drop down list of the service settings page...
Marcus Sen
British Geological Survey
Keyworth
Nottingham
NG12 5GG
Web: http://www.bgs.ac.uk
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
