Dear Devs,
I would like to introduce a very small but useful community module, WFS Freemarker Template.
This one is a super-light module which basically allows to expose the HTML output, the same used by the WMS module to render the GetFetureInfo one, for the WFS too.
The extension is optional, of course, and therefore the now output format will be enabled only when installing the module.
The WFS FreeMarker plugin enables the application of a FreeMarker template to a WFS GetFeature response, allowing for the generation of HTML output, akin to the functionality already present for WMS GetFeatureInfo requests.
It leverages the same logic and machinery utilized in templating WMS responses, utilizing the org.geoserver.wms.featureinfo.HTMLTemplateManager mechanism.
This feature is also accessible on the Layer Preview page in GeoServer, where a new HTML output format is provided for the WFS preview.
NOTE: This module requires a minor refactoring of the WMS GetFeatureInfo classes in order to expose the HTMLFreemarkerTemplate private class as a public one.
Alessio Fabiani
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
mob: +39 331 6233686
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
