[Geoserver-devel] Introduction
Hello,
My name is Ronald Hoek.
I’m a spectrum wide application developer (analyst, design, programming, testing, user support, bug-fixing, etc.) for a company in the Netherlands.
Recently (this year) we created an application (using Delphi), which matches geo-data from different (secure) sources with each other.
Because this data was not always available as a service (and the data was to large to distribute), I started looking for a (web)service, which could ‘host’ that geo-data, so the application could request only parts of the complete set.
Then I found GeoServer as one of the first hits, and I was really positively surprised by all the possibilities the application has. We did not look very far for other solutions, because GeoServer looked so promising and showed some exceled behavior an performance during the first tests and the fact GeoServer showed very active development.
But as always all software has issues ( https://osgeo-org.atlassian.net/browse/GEOS-8683 ).
So now here I am – as a newby to GeoServer – offering to help with further development of GeoServer.
As I’m not a Java Developer, but a Windows Application Developer, for now I would like to help with tuning the Windows Installer.
I would suggest the following changes in the installer behavior:
  • Never to overwrite/delete/add files in an existing ‘data_dir’
  • Suggest to the user to use a ‘data_dir’ outside the application directory
    • Note: it’s best to uninstall the software before upgrading, as the ‘old’ Windows Service Entry is removed and a new one is created
Maybe other issue might be changed in due time.
But for now these are the two issues I would like to change (I also need to learn NSIS first…)
Ronald Hoek
ComponentAgroB.V.
Oud-Beijerland - The Netherlands
Website: http://www.componentagro.nl
KvK: H24264020
Hi Ronald,
thanks for joining and introducing yourself. Find my comments below inline.
On Mon, Apr 16, 2018 at 3:31 PM, Ronald Hoek - ComponentAgro B.V. <ronald.hoek@anonymised.com> wrote:
Yep, we surely need someone to help on the Windows side :slight_smile:
Seems reasonable, GeoServer should upgrade the contents of the data dir on startup if strictly needed (that cannot be fully avoided,
but we try to limit that to a very small number of cases).
Maybe also suggest people to backup the data directory before proceeding with the upgrade.
Agreed on this one as well.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hello Andrea,
I’ve taken a bit of time to look into the NSIS ‘world’ and when I look at the script, it seems is requires file base on the location the script file if located.
However, it looks like these files are scattered across the repo, which requires me to create a copy of these file for testen the setup script.
I was wondering whether this is a required, as the automated build system creates this required set of files first and then compiles the script in the same location.
As said, the file are also (partially) available across the repo, so pointing to them (using relative path names) from within the script file, will not required a special copy of that data.
However, I don’t know how the setup is created by you (of the build system) at this time.
Can you give me some info, about how you create the setup at your end?
Ronald Hoek
On Wed, Apr 18, 2018 at 11:27 AM, Ronald Hoek - ComponentAgro B.V. <
Hello Andrea,
if located.
the same location.
Yes, you should first run a release build that generates the required base
zip file, something like:
cd src
mvn clean install -T2 -DskipTests -Prelease
mvn assembly:attached -Prelease -DskipTests
The -DskipTests is required as GeoServer won't build with tests on Windows
(we lack a windows developer caring for it, and you
don't really need tests anyways for your purpose).
The output will be in src/target/release
As an alternative, you can just pick the -bin.zip file from the nightly
builds directly, e.g.:
https://build.geoserver.org/geoserver/master/geoserver-master-latest-bin.zip
GeoServer Professional Services from the experts! Visit GeoSolutions Enterprise Support Services
Ing. Andrea Aime
@geowolf
Technical Lead
Hello Andrea,
For testing I now used the ‘bin.zip’ content (as I don’t; have the environment set up for building GeoServer).
I’ve created a pull request (on the master) to change the installer behavior (pull contains two commits).
However I have two more (smaller) issues, which I fixed too:
  • The NSIS compiler gives warnings about a non-existing LANGUAGE identifier
  • Cleanup ‘work’ folder after install
Can I create these in the issue tracker and make two pull request for them?
  • Or two different commits (and one pull)
Ronald Hoek
On Wed, Apr 18, 2018 at 2:43 PM, Ronald Hoek - ComponentAgro B.V. <
Hello Andrea,
   - The NSIS compiler gives warnings about a non-existing LANGUAGE
   identifier
   - Cleanup ‘work’ folder after install
   - Or two different commits (and one pull)
Both work... or you can even attach them into your original pull request,
in separate commits. Our norm is "one commit per ticket",
though there are deviations.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
