I have a layer of mining processes in geoserver
I need to implement a functionality where the user can filter mining
processes from a shape file.
This shape file contains 15 polygons and each polygon contains approximately
30k coordinates.
I'm using a post request and sending the 30k coordinates in a CQL, like the
one below.
cql = "INTERSECTS(the_geom, POLYGON((-40.9266886103044 -16.262666496441046,
-40.90549282420962 -16.263061436643454, -40.905472448859044
-16.263441492330248, -40.90229656699312 -16.267723288825366,
-40.90024952920471 -16.278586398087867... + 30k coordinates)
But the return is very slow. Because I have 15 polygons that perform this
CQL, with their respective coordinates.
Is there any better way to do this?
Sorry about my english lol
Thanks in advance
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-Dev-f3819232.html
you may want to have a look at:
https://docs.geoserver.org/stable/en/user/extensions/querylayer/index.html
A few comments:
- is the first layer in a database?
- sending a CQL filter with 15 polygons with more than 30K coordinates each will be slow to POST and for GeoServer to parse … you need to avoid this POST
- in terms of execution, some simplification of the polygons should be made
Hope it helps,
Nuno Oliveira
30k coordinates.
one below.
Thanks in advance
Sent from: [http://osgeo-org.1560.x6.nabble.com/GeoServer-Dev-f3819232.html](http://osgeo-org.1560.x6.nabble.com/GeoServer-Dev-f3819232.html)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the
experts!
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mail.
1 - is the first layer in a database?
Yes, it's unique.
The form that contains the coordinates, I have only one geojson with the
coordinates.
2 - sending a CQL filter with 15 polygons with more than 30K coordinates
each will be slow to POST and for GeoServer to parse ... you need to avoid
this POST
How i can do it without post request?
Thanks!
Possibly by storing the coordinates on the backend and refer to the by id. But still, filtering
with intersection against a polygon with 30k coordinates will be slow, no matter what.
You can have a look at where the time is spent using a profiler, have a look at “Mission Control”,
it’s a free profiler included in the JDK (from version 8 onwards), it will tell you where most of
the time is spent and may lead you to some obvious optimization (or not! )
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
