[Geoserver-devel] Issues managing the "latest" build on build.geoserver.org/geoserver ?
I wanted to ask on the user for volunteers list to test the EPSG 9.6 upgrade, but before
doing so, I checked the latest nightly build:
https://build.geoserver.org/geoserver/master/geoserver-master-latest-bin.zip
and found the database upgrade was not in there. In fact, the gt-hsql-epsg jar contained in there has the following manifest:
Manifest-Version: 1.0
Automatic-Module-Name: org.geotools.epsg_hsql
Build-Timestamp: 03-Jul-2019 15:47
Built-By: ubuntu
Class-Path: gt-referencing-22-SNAPSHOT.jar ejml-ddense-0.34.jar ejml-c
ore-0.34.jar commons-pool-1.5.4.jar gt-metadata-22-SNAPSHOT.jar gt-op
engis-22-SNAPSHOT.jar systems-common-java8-0.7.2.jar uom-se-1.0.8.jar
unit-api-1.0.jar uom-lib-common-1.0.2.jar si-quantity-0.7.1.jar si-u
nits-java8-0.7.1.jar commons-lang3-3.8.1.jar jgridshift-1.0.jar Geogr
aphicLib-Java-1.49.jar hsqldb-2.4.1.jar jai_core-1.1.3.jar
Project-Version: 22-SNAPSHOT
Git-Revision: 1e0c0d814869b81f6ab8166a0726def041e2c5db
Created-By: Apache Maven 3.6.0
Build-Jdk: 1.8.0_212
and still contains the 8.6 database. Checking another jar, a GeoServer one, the situation is the same:
Application-Name:
Implementation-Title: Web Coverage Service 1.1 Module
Implementation-Version: 2.16-SNAPSHOT
Build-Timestamp: 03-Jul-2019 16:03
Archiver-Version: Plexus Archiver
Built-By: ubuntu
Specification-Vendor: Open Source Geospatial Foundation
Specification-Title: Web Coverage Service 1.1 Module
Implementation-Vendor-Id: org.geoserver
GeoServerModule: core
Project-Version: 2.16-SNAPSHOT
Implementation-Vendor: Open Source Geospatial Foundation
Iteration-Name:
Git-Revision: ad7eb9041ff5dab135cba61798e8415c3b91097d
Specification-Version: 2.16-SNAPSHOT
Looking at a timestamped bin zip instead, e.g.:
https://build.geoserver.org/geoserver/master/geoserver-master-2019-07-11-war.zip
then the artifacts are up to date:
Application-Name:
Implementation-Title: REST UI Module
Build-Timestamp: 11-Jul-2019 12:08
Built-By: ubuntu
Specification-Title: REST UI Module
Implementation-Vendor-Id: org.geoserver.web
Iteration-Name:
Git-Revision: c54025e96071ed96f8aeb5392af1ed4a1d9255b5
So it seems there is an issue with managing the “latest” file/link?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I took a look today and couldn’t reproduce - everything had a manifest that looked like the following:
Build-Timestamp: 16-Jul-2019 14:45
Built-By: ubuntu
Git-Revision: 4683776b590f23ccc5c67044b6b875905e76f770
There is likely still be a persistent issue here, but it doesn’t seem to happen consistently - I’ll take a look again in a couple days, and see if there is any discrepancy then.
Torben
On Fri, Jul 12, 2019 at 1:32 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Built-By: ubuntu
Application-Name:
Built-By: ubuntu
Iteration-Name:
Application-Name:
Built-By: ubuntu
Iteration-Name:
Geoserver-devel mailing list
Okay, I might have fixed this, but I’m still having trouble reproducing the issue, so I’m not certain (I’d though I’d reproduced it today, but then found out GeoTools was last built on the 15th, so now I’m not sure).
I think the problem was that the copy wasn’t overwriting existing files (but since old files get cleaned up every week, it was eventually getting replaced by a new one). If this is the issue, it should now be fixed.
I’lll check again in a couple days to see if I can still reproduce the issue…
Torben
On Tue, Jul 16, 2019 at 2:35 PM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Built-By: ubuntu
Torben
Built-By: ubuntu
Application-Name:
Built-By: ubuntu
Iteration-Name:
Application-Name:
Built-By: ubuntu
Iteration-Name:
