On Thu, Jun 15, 2017 at 3:49 PM, Niels Charlier <niels@anonymised.com> wrote:
Hello list,
The jdbcconfig module seriously slows down the response time of requests.
I discovered that it sends dozens of SQL queries to the db per request,
even though jdbcconfig uses a cache.
Turns out that the cache is only by id, but most queries to the catalog
are actually by name. For each ows request, the layer, workspace,namespace,
resource, etc... are all queried from the catalog multiple times by name,
resulting in many (duplicated) SQL queries.
Yes, all of the above is well known, it was discussed in January already
during as part of GSIP 155 (part by mail, part during the PSC meeting, part
on gitter).
So my suggestion would be to store catalog objects in the cache not only
by ID, but also by CATALOGINFOTYPE::NAME or something like that. Then we
can use the cache in all of the get[CATALOGINFOTYPE]ByName methods.
Are there any objections and/or suggestions to this proposal?
Nowadays there is from a cache keyed by immutables (ids), you are adding a
cache of mutables (I believe you need to cache by qualitified name, ws:
name), so how are you going to spread the word across cluster nodes when a
layer or workspace name changes, or gets removed? Is the hz-cluster
covering this already?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
phone: +39 0584 962313 <+39%200584%20962313>
fax: +39 0584 1660272 <+39%200584%20166%200272>
mob: +39 339 8844549 <+39%20339%20884%204549>
