UI-based logfile control partially broken because of commons-logging functionality
Key: GEOS-1022
URL: http://jira.codehaus.org/browse/GEOS-1022
Project: GeoServer
Issue Type: Bug
Components: Error Reporting, Global
Reporter: Saul Farber
Assigned To: Saul Farber
Fix For: 1.5.1, 1.6.0
With the new commons-logging integration there's a problem with the logging functionality expressed via the geoserver UI.
The UI seems to say that you can choose a specific file to log your output to, but you can't do that easily with just commons-logging as the baseline.
We need to either remove this functionality, or figure out another way to do/express this.
