[Geoserver-devel] [jira] Created: (GEOS-1185) DescribeFeature fails if no namespace is declared
                 Key: GEOS-1185
                 URL: http://jira.codehaus.org/browse/GEOS-1185
             Project: GeoServer
          Issue Type: Improvement
          Components: WFS
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
            Priority: Blocker
             Fix For: 1.6.0
The following request fails:
<!-- A sample describe request. The schema is generated automatically by -->
<!-- GeoServer. You can modify the schema with the web interface to hide -->
<!-- and/or require certain attributes. -->
      If you change the "<TypeName>" tag below to the name of another
      dataset, you can see the GML Schema for that layer.
      This will have all the column names and types.
      The getCapabilities demo will tell you the names of all the layers!
<DescribeFeatureType
  version="1.0.0"
  service="WFS"
  xmlns="http://www.opengis.net/wfs&quot;
  xmlns:topp="http://www.openplans.org/topp&quot;
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
  xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd&quot;&gt;
    <TypeName>tiger:coastline</TypeName>
</DescribeFeatureType>
It fails because the parsed QName has no Namespace information, but only prefix one. This is because the "tiger" namespace
hasn't been declared. DescribeFeatureType will compare namespaces, not prefixes, making the type not found.
I'm wondering how to handle this the general way. Could we override somehow the QName parsing so that if the
Namespace is not declared, the prefix is used to access the Geoserver catalog and populate the namespace anyways?
It would be a way to make a patch in just one point, instead of chasing all users of QName.getLocalPart.
I can fix this one myself, just need your advice on how to address it.
