[Geoserver-devel] [jira] Created: (GEOS-1216) Have Logging config set Java Logger levels to mirror log4j configuration file
                 Key: GEOS-1216
                 URL: http://jira.codehaus.org/browse/GEOS-1216
             Project: GeoServer
          Issue Type: Bug
          Components: Error Reporting
            Reporter: Saul Farber
            Assignee: Saul Farber
             Fix For: 1.6.0-alpha2
Right now Java Logging is set entirely to Level.ALL on org.geotools, org.vfny and org.geoserver loggers. We should read the log4j config file and set the loggers to the appropriate levels based on the actual configuration.
