[Geoserver-devel] [jira] Created: (GEOS-1220) GetFeatureInfo GML output cite test failure
                 Key: GEOS-1220
                 URL: http://jira.codehaus.org/browse/GEOS-1220
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.6.0-beta1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
            Priority: Blocker
             Fix For: 1.6.0-rc1
Test wms:wmsops-getfeatureinfo-params-info_format-3 (s0013/w6ac25b3c31d221b1_1)
Assertion: When the INFO_FORMAT parameter is application/vnd.ogc.gml, then the response validates with the Galdos GML instance document validator.
Parameter VAR_WMS_VERSION:
   Label: 1.1.1
   Value: 1.1.1
Parameter VAR_LAKES:
   Label: cite:Lakes
   Value: cite:Lakes
Parameter VAR_IMAGE_FORMAT:
   Label: application/pdf
   Value: application/pdf
Parameter VAR_WMS_GET_FEATURE_INFO_HTTP_GET_URL:
   Label: http://82.50.107.99:8080/geoserver/wms?SERVICE=WMS&
   Value: http://82.50.107.99:8080/geoserver/wms?SERVICE=WMS&
Request w6ad125c15b1b1_1:
   Method: get
   URL: http://82.50.107.99:8080/geoserver/wms?SERVICE=WMS&&QuErY_LaYeRs=cite:Lakes&BbOx=0,-0.0020,0.0040,0&FoRmAt=application/pdf&ReQuEsT=GetFeatureInfo&VeRsIoN=1.1.1&InFo_fOrMaT=application/vnd.ogc.gml&X=60&StYlEs=&LaYeRs=cite:Lakes&SrS=EPSG:4326&WiDtH=200&HeIgHt=100&Y=60
   Response from parser wms:GMLValidatingParser:
   Messages from parser wms:GMLValidatingParser:
        error at line 8, column 34 of http://82.50.107.99:8080/geoserver/wfs?version=1.0.0&request=DescribeFeatureType&typeName=cite:Lakes:
  s4s-elt-character: Non-whitespace characters are not allowed in schema elements other than xs:appinfo and xs:documentation. Saw 'Could not determine service'.
error at line 6, column 123 of http://82.50.107.99:8080/geoserver/wfs?version=1.0.0&request=DescribeFeatureType&typeName=cite:Lakes:
  s4s-elt-schema-ns: The namespace of element 'ServiceExceptionReport' must be from the schema namespace.
  s4s-elt-invalid: Element 'ServiceExceptionReport' is not a valid element in schema document.
  schema_reference.4: Failed to read schema document 'http://82.50.107.99:8080/geoserver/wfs?version=1.0.0&request=DescribeFeatureType&typeName=cite:Lakes’, because 1) could not find the document; 2) the document could not be read; 3) the root element of the document is not <xsd:schema>.
error at line 1, column 815:
  cvc-complex-type.2.4.a: Invalid content starting with element 'cite:Lakes'. The content must match '(("http://www.opengis.net/gml&quot;:\_Feature\)){0-1}'.
17 errors detected.
Result: Failed
