[Geoserver-devel] [jira] Created: (GEOS-13) Add mandatory attributes
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-13
Here is an overview of the issue:
        Key: GEOS-13
    Summary: Add mandatory attributes
       Type: Task
     Status: Open
   Priority: Major
Original Estimate: 2 hours, 30 minutes
Time Spent: Unknown
  Remaining: 2 hours, 30 minutes
    Project: GeoServer
Components:
             Configuration
   Fix Fors:
             1.1.0
   Versions:
             1.1beta
   Assignee: Chris Holmes
   Reporter: Chris Holmes
    Created: Wed, 10 Dec 2003 3:38 PM
    Updated: Wed, 10 Dec 2003 3:38 PM
Description:
In version 1.0.* one could set an attribute as 'mandatory', ensuring that it was returned every time. This is a bit hacky, in an ideal world one should be able to just set the schema to minOccurs=1 and it will automatically return. But the geotools gml parser needs to get a lot better first. So until then we will just set it in the info.xml file for featureTypes. This should fit in nicely with the newly added 'exposed' attributes, where one can specify which attributes to expose. We will just add an attribute mandatory="true".
As for coding this, unfortunately geotools doesn't support the mandatory concept. So for now we can hack it in to geoserver, and just add it to the query request. We may be able to wrap the schema to do it a bit more elegantly.
This functionality is needed to pass cite tests, getFeature #4
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
