[Geoserver-devel] [jira] Created: (GEOS-1300) Unable to Deploy on Tomcat using J2SDK1.4.2_15
                 Key: GEOS-1300
                 URL: http://jira.codehaus.org/browse/GEOS-1300
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.5.3, 1.5.1
         Environment: Cent OS 4.4
Java SDK 1.4.2_15
Tomcat 5.5
            Reporter: Lee Nguyen
            Assignee: Andrea Aime
After installing Tomcat, upon deploying the 1.5.3 or the 1.5.1 WAR file into Tomcat using the Tomcat Manager, GeoServer failed to deploy with the following message:
FAIL - context path /geoserver could not be started
The catalina.out log can be found here: http://rafb.net/p/IZx6SZ44.html
However, upon intsalling Java JDK 1.5.0_12 it was able to run.
I'm still not sure why this happened.
