Improve the OL preview
Key: GEOS-1382
URL: http://jira.codehaus.org/browse/GEOS-1382
Project: GeoServer
Issue Type: Improvement
Components: UI
Affects Versions: 1.6.0-beta3
Reporter: Andrea Aime
Assignee: Tim Schaub
Fix For: 1.6.0-beta4
I hear you have ideas about improving the map preview, so here we go.
One thing I would like to see is some way to dynamically switch the image type
for the layers, and maybe a switch to control antialiasing, so that people can
compare the various options and see what's the best for them.
As for the rest, I'm sure you have plenty of ideas ![]()
The preview is dinamically generated using Freemarker templates. To ease
up your work, you could redo the preview as a static html file and then
I can translate it into a freemarker template. As an alternative, I can assist
you setting up a developer enviroment so that you can play against the freemarker
template directly. Just let me know.
