WFS should qualify envelopes with the _declared_ default SRS
Key: GEOS-1436
URL: http://jira.codehaus.org/browse/GEOS-1436
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 1.6.0-beta3
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 1.6.0-RC1
The following WFS request:
fails (using a normally oriented datastore) because the bbox is parsed as of being in the datastore native srs, when it's not.
The specification says that if the bbox is not srs qualified the default srs must be used. The capabilities say that the default
srs is urn:x-ogc:def:crs:EPSG:6.11.2:4326, not EPSG:4326, so the above box must be flipped before hitting the datastore.
The kvp parser should make sure the SRS associated to bboxes is the one _declared_ in the WFS capabilities when not
provided. This also means the code will have to take care of the WFS version since we do specify EPSG:4326 in
WFS 1.0 but urn:x-ogc:def:crs:EPSG:6.11.2:4326 in WFS 1.1
