[Geoserver-devel] [jira] Created: (GEOS-1501) Old data dirs using "shapefile url" parameters aren't opened properly anymore
                 Key: GEOS-1501
                 URL: http://jira.codehaus.org/browse/GEOS-1501
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.6.0-beta4
            Reporter: Andrea Aime
            Assignee: Andrea Aime
            Priority: Critical
             Fix For: 1.6.0-RC1
When trying to open an old data dir using the indexed shapefile datastore the following error message is reported:
java.util.NoSuchElementException: No datastore found capable of managing DataStoreConfig[namespace=Regio2, enabled=false, abstract=null, connection parameters={namespace=http://www.geo-solutions.it, create spatial index=true, shapefile url=file:/C:/progetti/geoserver/data/neapolis/data/Neapolis/Regio2/pareteam.shp}]
This happens because the parameter has been renamed to "url". An ugly but effective workaround is to alter the config reader to turn "shapefile url"
into "url" during xml readering (the alternative would be to have shapaefile datastore parse both, but that would mean deprecating the param and would only delay the problem of what to do when it's removed).
