[Geoserver-devel] [jira] Created: (GEOS-164) cannot access 'http://www.digitalearth.gov/wmt/xml/exception_1_1_0.dtd'
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-164
Here is an overview of the issue:
        Key: GEOS-164
    Summary: cannot access 'http://www.digitalearth.gov/wmt/xml/exception_1_1_0.dtd
       Type: Bug
     Status: Open
   Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
             WMS
   Versions:
             1.2.0-rc1
   Assignee: Gabriel Roldán
   Reporter: Scott Pezanowski
    Created: Sun, 9 May 2004 9:01 PM
    Updated: Sun, 9 May 2004 9:01 PM
Environment: Windows, Tomcat 5.0.19
Description:
I download geoserver.war. First I went to http://localhost:8080/geoserver and had no errors in compilation. Then I tried to access the following url
http://localhost:8080/geoserver/wms?request=GetMap&layers=bc_shapefile&bbox=489153,5433000,%20529000,5460816&width=400&height=200&srs=EPSG:27354&styles=normal&Format=image/png
and I received the following message:
The XML page cannot be displayed
Cannot view XML input using style sheet. Please correct the error and then click the Refresh button, or try again later.
The system cannot locate the resource specified. Error processing resource 'http://www.digitalearth.gov/wmt/xml/exception_1_1_0.dtd’.
Thanks for any help.
Scott
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
I'm glad some else noticed this. I've switched my server to use
http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd which seems
to work and is probably better in the long run too.
Ian
Ian Turton, Director, Centre for Computational Geography, University of
Leeds, Leeds, LS2 9JT
http://www.geog.leeds.ac.uk/people/i.turton http://www.ccg.leeds.ac.uk
http://www.geotools.org
+44 (0) 113 343 3392 fax: +44 (0) 113 343 3308
