[Geoserver-devel] [jira] Created: (GEOS-1679) NPE while configuring FeatureTypes
                 Key: GEOS-1679
                 URL: http://jira.codehaus.org/browse/GEOS-1679
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.6.x
            Reporter: David Winslow
            Assignee: Andrea Aime
While configuring a FeatureType, a NullPointerException can be forced. To reproduce:
* Start Geoserver using the configuration/release dataset
* Go into the configuration interface and edit the DS_giant_polygon:giant_polygon featuretype
* Set the SRS to 900913 and submit
* Edit it again and set the SRS back to 4326; when you submit there will be an NPE
