wms reflector does not work with pure remote slds
Key: GEOS-1696
URL: http://jira.codehaus.org/browse/GEOS-1696
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.6.0-RC3
Reporter: Chris Holmes
Assignee: Arne Kepp
Priority: Minor
Fix For: 1.6.1
http://geo.openplans.org:8080/geoserver/wms/reflect?Format=application/kml+xml&sld=http://artois.openplans.org/slds/population.sld no longer works. Or indeed
This is very minor because its a seldom known option, to have the layer defined within the sld.
java.lang.NullPointerException
at org.geoserver.wms.DefaultWebMapService.autoSetBoundsAndSize(DefaultWebMapService.java:227)
at org.geoserver.wms.DefaultWebMapService.getMapReflect(DefaultWebMapService.java:165)
at org.geoserver.wms.DefaultWebMapService.reflect(DefaultWebMapService.java:137)
is the error. Obviously the code's expecting the layer param to be there.
I don't know that it is even worth supporting this option. If it's easy to then sure, if not we should just make a better error message for the reflector.
