[Geoserver-devel] [jira] Created: (GEOS-1758) Install and attach source jars
                 Key: GEOS-1758
                 URL: http://jira.codehaus.org/browse/GEOS-1758
             Project: GeoServer
          Issue Type: Improvement
    Affects Versions: 1.6.x
            Reporter: Ben Caradoc-Davies
            Assignee: Andrea Aime
            Priority: Minor
         Attachments: geoserver-1.6.x-pom-attach-source.patch
Modify GeoServer 1.6.x top-level POM to create and install source jars, and attach them when Eclipse projects are generated. This will aid debugging for those modules (web-c) that resolve core geoserver dependencies through the Maven repository at runtime (to avoid transitive dependencies).
The changes in the attached patch were stolen from the GeoTools top-level POM, and have been modified only to match the formatting of the GeoServer POM.
This patch is against 1.6.x, but trunk would benefit from the same change.
