[Geoserver-devel] [jira] Created: (GEOS-1764) GetMapResponse finalizer might throw an NPE
                 Key: GEOS-1764
                 URL: http://jira.codehaus.org/browse/GEOS-1764
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.6.0
            Reporter: Andrea Aime
            Assignee: Andrea Aime
            Priority: Trivial
             Fix For: 1.6.1
From a GeoServer 1.6.x log:
{code}
23 feb 18:19:39 ERROR [wms.responses] - Getting feature source: null
java.lang.NullPointerException
  at org.vfny.geoserver.wms.responses.GetMapResponse.clearMapContext(GetMapResponse.java:542)
  at org.vfny.geoserver.wms.responses.GetMapResponse.finalize(GetMapResponse.java:628)
  at java.lang.ref.Finalizer.invokeFinalizeMethod(Native Method)
  at java.lang.ref.Finalizer.runFinalizer(Finalizer.java:83)
  at java.lang.ref.Finalizer.access$100(Finalizer.java:14)
  at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:160)
{code}
A null check in the clearMapContext method is all that is needed to fix this buglet
