UI config hangs if an OOM is generated during config load - should catch and report gracefully
Key: GEOS-1779
URL: http://jira.codehaus.org/browse/GEOS-1779
Project: GeoServer
Issue Type: Improvement
Components: UI
Affects Versions: 1.6.0
Reporter: Rob Atkinson
Assignee: Andrea Aime
UI config hangs (doesnt return to browser ever) if an OOM is generated during config load - should catch and report gracefully
ideally it would be nice to report the system config (java memory) during UI operations, this would also aid us catching memory leaks..
