[Geoserver-devel] [jira] Created: (GEOS-1814) Versioning instructions omit PostGIS init steps
                 Key: GEOS-1814
                 URL: http://jira.codehaus.org/browse/GEOS-1814
             Project: GeoServer
          Issue Type: Improvement
          Components: Versioning
    Affects Versions: 1.6.2
         Environment: 1.6.2 versioning
            Reporter: Scot E. Wilcoxon
            Assignee: Andrea Aime
            Priority: Trivial
The versioning file wfsv-readme.txt says a spearfish database should be created. I think this is supposed to be a PostGIS database but the instructions omit the PostGIS initialization, as described in http://geoserver.org/display/GEOSDOC/6+Versioning
createlang plpgsql -U postgres spearfish
psql -U postgres -d spearfish -f /usr/share/lwpostgis.sql
psql -U postgres -d spearfish -f /usr/share/spatial_ref_sys.sql
