Use Hints.JTS_COORDINATE_SEQUENCE_FACTORY un WFS GetFeature queries and CoordinateSequence in the encoder
Key: GEOS-1869
URL: http://jira.codehaus.org/browse/GEOS-1869
Project: GeoServer
Issue Type: Improvement
Components: WFS
Affects Versions: 1.6.3
Reporter: Gabriel Roldán
Assignee: Gabriel Roldán
Fix For: 1.6.4
Some datastores know about the Query hint {{Hints.JTS_COORDINATE_SEQUENCE_FACTORY}} and can use a lighter weight coordinate sequence.
Problem is the current GML2 and GML3 do not currently use CoordinateSequence but coordinate, so they need to be switched to CoordinateSequence for the hint to make any good.
