[Geoserver-devel] [jira] Created: (GEOS-191) Multiple Inserts in Single Transaction Mangle Data
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/browse/GEOS-191
Here is an overview of the issue:
        Key: GEOS-191
    Summary: Multiple Inserts in Single Transaction Mangle Data
       Type: Bug
     Status: Open
   Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
   Versions:
             1.2.0-rc2
   Assignee: Chris Holmes
   Reporter: John Stiening
    Created: Wed, 7 Jul 2004 1:23 PM
    Updated: Wed, 7 Jul 2004 1:23 PM
Environment: Tomcat, PostGIS, and Geoserver 1.2.0-rc2
Description:
Basically I am attempting to insert 30 features in a single transaction, and have noticed that while the transaction will claim that the features inserted properly, the data in the database is mangles. Increasing or decreasing the number of features(obs in my case) allows me to move the mangled spot around. The mangled spot includes only a portion of the data that is supposed to be in it. (e.g "CLIPPER SEA" becomes "SEA" in some iterations.) The weird thing is that it can chop out the middle of a data value as well, and not just one of the ends. I will post both db output and insert xml for you all to see.
Obervations
1) <DC:destination/> caused problems, while <DC:destination></DC:destination> did not.
2) Different lenghts of text in each data element appear to cause problems as well. My lat long coordinates had a few coordinates that were of slighly lower precision. When I added zeros for padding, the problem of mangled data mostly went away.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
